removing items from the popup menu [message #177973] |
Tue, 18 March 2008 15:33  |
Originally posted by: chrisn86.yahoo.de
I know that this question was asked several times before, but after all
I still didn't got it working.
I want to remove some actions and sub menus from the pop-up menu and the
main menu bar. I know about the 'popupPredefinedItem' in
'org.eclipse.gmf.runtime.common.ui.services.action.contribut ionItemProviders'
and I have tried to use this snippet from the example:
<popupPredefinedItem
id="autoSizeAction"
path="/formatMenu/"
remove="true"/>
Apart from that the autosizeAction in my diagram menu is always
disabled, it is still visible. What am I doing wrong?
It would be nice if somebody could give me a working example for
removing the copy action or the whole filter menu!
Christian Neudert
Re: removing items from the popup menu [message #178471 is a reply to message #178226] |
Thu, 20 March 2008 15:17   |
--------------060405000406080703050004
Hi Cherie,
I've attached the interesting part of my plugin.xml. I also completely
recreated my diagram plug-in, but I still can't filter any pop-up action
through popupPredefinedItem..
Thanks for the bug hint. After I read the comment #2 I implemented my
own DiagramContextMenuProvider and needed to overwrite
configureGraphicalViewer() in my DiagramDocumentEditor to register this
Provider. With this "hack" I can filter the pop-up menu through
allowItem(IContributionItem itemToAdd). By the way, its possible to
remove the toolbar actions, after they have been created, if you filter
them in your DiagramActionBarContributor.
For now these workarounds are sufficent, but i would like to use the
smart way with popupPredefinedItem.
Christian
Cherie Revells schrieb:
> Christian,
> Your snippet looks fine, but what else are you setting in the
> contributionItemProviders extension point?
> By the way, you will only be able to remove the autosize action from the
> context menu this way and not from the main menu or toolbar (see
> Bugzilla 111221 for more info).
> Regards,
> Cherie
name="snippet.txt"
Content-Disposition: inline;
filename="snippet.txt"
<extension point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<?gmfgen generated="true"?>
<contributionItemProvider class="petri.diagram.providers.PetriContributionItemProvider ">
<Priority name="Low">
</Priority>
<partContribution id="petri.diagram.part.PetriDiagramEditorID">
<partAction menubarPath="/file/print" id="printPreviewAction">
</partAction>
</partContribution>
</contributionItemProvider>
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContribu tionItemProvider "
checkPluginLoaded="false">
<Priority name="Low"/>
<popupContribution class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider ">
<popupStructuredContributionCriteria objectClass="petri.diagram.edit.parts.StelleNameEditPart"/ >
<popupPredefinedItem id="deleteFromDiagramAction" remove="true"/>
<popupPredefinedItem id="deleteFromModelAction" remove="true"/>
<popupPredefinedItem id="autoSizeAction" path="/formatMenu/" remove="true"/>
</popupContribution>
<popupStructuredContributionCriteria objectClass="petri.diagram.edit.parts.TransitionNameEditPart "/>
<popupStructuredContributionCriteria objectClass="petri.diagram.edit.parts.Connection1GewichtEditPart "/>
<popupStructuredContributionCriteria objectClass="petri.diagram.edit.parts.Connection2GewichtEditPart "/>
</extension>
--------------060405000406080703050004--
Re: removing items from the popup menu [message #178500 is a reply to message #178471] |
Thu, 20 March 2008 16:11   |
Christian,
Are you saying that with the code in your plugin.xml you were able to
remove the delete menu items, but not the autosize menu item? I do not
understand why. I did the following to remove the autosize menu item
from the geoshapes example and it worked fine. It looks teh same as to
what you have.
<extension
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContribu tionItemProvider ">
<Priority
name="Low">
</Priority>
<popupContribution
objectClass=" org.eclipse.gmf.runtime.diagram.ui.geoshapes.internal.editpa rts.GeoShapeEditPart ">
</popupStructuredContributionCriteria>
id="autoSizeAction"
path="/formatMenu/"
remove="true">
</popupPredefinedItem>
</extension>
Cherie
christian Neudert wrote:
> Hi Cherie,
> Regards,
> Christian
>> Christian,
>> the context menu this way and not from the main menu or toolbar (see
>> Regards,
>> Cherie
> </Priority>
> </partAction>
> </partContribution>
> </extension>
FUDForum. Page generated in 0.04101 seconds
