Home » Eclipse Projects » Sirius » Unable to install UML to JAVA( Problems occurred while performing installation: Operation details)
Unable to install UML to JAVA [message #1784656] Sun, 01 April 2018 06:20 Go to next message
Hey,
I'm using UML designer ( an eclipse version) and when I want to install UML TO JAVA via Install UML Components, I get this error :
Message : Problems occurred while performing installation: Operation details
Exception Stack trace :
java.lang.RuntimeException: Operation details
at org.eclipse.amalgam.discovery.ui.common.internal.PrepareInstallProfileJob.resolve(PrepareInstallProfileJob.java:165)
at org.eclipse.amalgam.discovery.ui.common.internal.PrepareInstallProfileJob.run(PrepareInstallProfileJob.java:115)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
I was using Eclipse JUNO and I faced the same problems!
So if u knw what should I do, please tell me!
Thank u ^^
Re: Unable to install UML to JAVA [message #1784657 is a reply to message #1784656] Sun, 01 April 2018 06:27 Go to previous messageGo to next message
UML Designer is a proprietary product. You should seek information on its communication channels.
Ed Willink
Re: Unable to install UML to JAVA [message #1784658 is a reply to message #1784657] Sun, 01 April 2018 06:28 Go to previous messageGo to next message
and where is that exactly!!
Thank u
Re: Unable to install UML to JAVA [message #1784659 is a reply to message #1784658] Sun, 01 April 2018 06:35 Go to previous messageGo to next message
If you Google UML Designer it takes you to http://www.umldesigner.org/support/
Ed Willink
Re: Unable to install UML to JAVA [message #1784660 is a reply to message #1784659] Sun, 01 April 2018 07:42 Go to previous messageGo to next message
thank u
Re: Unable to install UML to JAVA [message #1784714 is a reply to message #1784657] Tue, 03 April 2018 03:27 Go to previous message
Ed Willink wrote on Sun, 01 April 2018 12:27
No, UML Designer is a free software available under the EPL license.
The documentation is available on the website :
The source code is available on gihtub :
https://github.com/ObeoNetwork/UML-Designer
You can find support on StackOverflow :
Previous Topic:The difference between open the diagram editor for the first time and open it for the second time
Next Topic:Mapping of a group of instances as a node in a diagram
Current Time: Sun Jul 20 12:01:16 EDT 2025
Powered by FUDForum. Page generated in 0.04107 seconds
