Home » Modeling » M2T (model-to-text transformation) » Can't install UML to java generator
Can't install UML to java generator [message #1784631] Fri, 30 March 2018 20:06 Go to next message
Hey,
So I'm using eclipse oxygen, and I installed UML designer successfully and then I had to install UML TO JAVA, but an error occured :
message : Problems occurred while performing installation: Operation details
Exception stack trace :
java.lang.RuntimeException: Operation details
at org.eclipse.amalgam.discovery.ui.common.internal.PrepareInstallProfileJob.resolve(PrepareInstallProfileJob.java:165)
at org.eclipse.amalgam.discovery.ui.common.internal.PrepareInstallProfileJob.run(PrepareInstallProfileJob.java:115)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
I don't knw what went wrong!
Help pls and thank u !
Re: Can't install UML to java generator [message #1784635 is a reply to message #1784631] Sat, 31 March 2018 04:43 Go to previous message
UML Designer is a proprietary product. You should seek information on its communication channels.
Ed Willink
Previous Topic:UML2JAVA
Next Topic: unable to install new softwares
Current Time: Sat Jul 19 19:38:48 EDT 2025
Powered by FUDForum. Page generated in 0.06803 seconds
