Home » Modeling » TMF (Xtext) » Xtext grammar which do not generate an EMF java interface(Build a generator based on the pared EMF metamodel)
Xtext grammar which do not generate an EMF java interface [message #1784472] Wed, 28 March 2018 07:17 Go to next message
I had a given grammar in Xtext, the rules is defined as following:
TExpression:
PARENTHESIS_OPEN TypeE PARENTHESIS_CLOSE | EXCLAMATION TExpression| TypeA| TypeB | TypeC |
TypeD;
PARENTHESIS_OPEN:
PARENTHESIS_CLOSE:
EXCLAMATION:
When I generate the EMF metamodel for this grammar specification, I only have the java interface for TExpression rule.
So how can I make the distinction in my generator that I am working with 'TExpression' object or ' EXCLAMATION TExpression' object?
Re: Xtext grammar which do not generate an EMF java interface [message #1784479 is a reply to message #1784472] Wed, 28 March 2018 09:36 Go to previous messageGo to next message
EXCLAMATION:
{EXCLAMATION}'!';
p.s: please use assignments in your grammar.
[Updated on: Wed, 28 March 2018 09:37] by Moderator
Re: Xtext grammar which do not generate an EMF java interface [message #1784537 is a reply to message #1784479] Thu, 29 March 2018 03:31 Go to previous messageGo to next message
Hi Christian,
It's not work in the way you mentioned. I got this following error at the definition of TExpression
Multiple markers at this line
- An unassigned rule call is not allowed, when the 'current'
was already created.
- Cannot change type twice within a rule
Do you have any idea on how to fix it?
Re: Xtext grammar which do not generate an EMF java interface [message #1784539 is a reply to message #1784537] Thu, 29 March 2018 03:32 Go to previous messageGo to next message
can you please share a actualy minimal but complete grammar example
TExpression:
TypeD;
makes no sense as i said
Re: Xtext grammar which do not generate an EMF java interface [message #1784540 is a reply to message #1784539] Thu, 29 March 2018 03:33 Go to previous messageGo to next message
TExpression:
"(" TypeE ")" | ({NotExpression}"!" expr=TExpression)| TypeA| TypeB | TypeC |
TypeD;
might
Re: Xtext grammar which do not generate an EMF java interface [message #1784548 is a reply to message #1784540] Thu, 29 March 2018 04:49 Go to previous message
Your suggestion worked for the '{Not Expression}'.....
Thank you so much!
Previous Topic:Auto edit DSL file on compile
Next Topic:Load external metamodel for LSP using gradle
Current Time: Sat Jul 19 18:51:33 EDT 2025
Powered by FUDForum. Page generated in 0.23851 seconds
