Home » Eclipse Projects » Eclipse Platform » Single-Click Rebuild Project
Single-Click Rebuild Project [message #1784389] Tue, 27 March 2018 10:08 Go to next message
Is there a single-click rebuild project (or rebuild all) option in Eclipse? Maybe a keyboard shortcut?
Re: Single-Click Rebuild Project [message #1784415 is a reply to message #1784389] Tue, 27 March 2018 14:25 Go to previous messageGo to next message
Projects > Clean... or equivalently using the Quick Access: Ctrl-3 and Build Clean. The Build Clean can be bound to a hot key from the Preferences > Keys dialog.
Re: Single-Click Rebuild Project [message #1784419 is a reply to message #1784415] Tue, 27 March 2018 15:11 Go to previous messageGo to next message
Thanks, but it doesn't rebuild anything when I that. After cleaning, I always have to actually run Build All (Ctrl+B).
Re: Single-Click Rebuild Project [message #1784420 is a reply to message #1784419] Tue, 27 March 2018 15:12 Go to previous messageGo to next message
Do you have Project > Build Automatically enabled?
Re: Single-Click Rebuild Project [message #1784424 is a reply to message #1784420] Tue, 27 March 2018 15:19 Go to previous messageGo to next message
Yes, Project > Build Automatically is enabled.
Re: Single-Click Rebuild Project [message #1784426 is a reply to message #1784420] Tue, 27 March 2018 15:32 Go to previous messageGo to next message
If you have Build Automatically turned off, then a Build Clean should have an option at the bottom to prostrate a build immediately. Otherwise a Build Clean should trigger an automatic build.
Could you describe your situation and what you're trying to do, or why you're having to do what you're doing?
Brian.
Re: Single-Click Rebuild Project [message #1784429 is a reply to message #1784426] Tue, 27 March 2018 15:46 Go to previous messageGo to next message
I disabled Project > Build Automatically, and now the Build Clean window shows the option you described and appears appears to work correctly. Thanks for the help. :)
Re: Single-Click Rebuild Project [message #1784431 is a reply to message #1784429] Tue, 27 March 2018 16:41 Go to previous message
Note that with Project > Build Automatically enabled, doing a Project > Clean... / Build Clean will automatically trigger a full rebuild. You will see a Building workspace job if you open the Progress view (Window > Show View > Other > Progress).
Previous Topic:Adding an extra buildCommand to the javaNature
Next Topic:Logging jobs
Current Time: Sun Jul 20 18:32:17 EDT 2025
Powered by FUDForum. Page generated in 0.03714 seconds
