Home » Eclipse Projects » EGit / JGit » After 4.7.3 upgrade, Eclipse thinks my git config is in a different place
After 4.7.3 upgrade, Eclipse thinks my git config is in a different place [message #1784148] Thu, 22 March 2018 19:35 Go to next message
In the past, I've noticed some oddities in the git configuration dialog. I have my .gitconfig in "C:\Users\<myuid>", but I often find eGit thinks it's in "H:\". When I've seen this in the past, I was simply able to change the path in the field to the correct one, and it would be fine for a while.
After the 4.7.3 upgrade, it appears that I can't even change this now.
I do have one environment variable that refers to that location, called "HOMEDRIVE". I find it hard to believe eGit uses that.
How do I get eGit to use the config location that I want?
Re: After 4.7.3 upgrade, Eclipse thinks my git config is in a different place [message #1784152 is a reply to message #1784148] Thu, 22 March 2018 20:11 Go to previous messageGo to next message
Is it using the "HOME" environment variable? I'm trying not to set that, because that confuses Cygwin.
Re: After 4.7.3 upgrade, Eclipse thinks my git config is in a different place [message #1784166 is a reply to message #1784152] Fri, 23 March 2018 03:50 Go to previous messageGo to next message
As you see below JGit on windows (if cygwin is not used) is using 1) HOME, 2) HOMEDRIVE/HOMEPATH and 3) HOMESHARE. Be aware that if cygwin is used than the code is again different (see FS_Win32_Cygwin#userHomeImpl())
> git describe
v4.11.0.201803080745-r-60-g901e663a6
> git grep -12 HOMEDRIVE
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-                       }
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-               return gitExe;
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-       /** {@inheritDoc} */
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-       @Override
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-       protected File userHomeImpl() {
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-               String home = SystemReader.getInstance().getenv("HOME"); //$NON-NLS-1$
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-               if (home != null)
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-                       return resolve(null, home);
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java:               String homeDrive = SystemReader.getInstance().getenv("HOMEDRIVE"); //$NON-NLS-1$
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-               if (homeDrive != null) {
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-                       String homePath = SystemReader.getInstance().getenv("HOMEPATH"); //$NON-NLS-1$
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-                       if (homePath != null)
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-                               return new File(homeDrive, homePath);
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-               String homeShare = SystemReader.getInstance().getenv("HOMESHARE"); //$NON-NLS-1$
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-               if (homeShare != null)
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-                       return new File(homeShare);
org.eclipse.jgit/src/org/eclipse/jgit/util/FS_Win32.java-               return super.userHomeImpl();
Re: After 4.7.3 upgrade, Eclipse thinks my git config is in a different place [message #1784221 is a reply to message #1784166] Fri, 23 March 2018 13:08 Go to previous messageGo to next message
Thanks, but that only confirms that I don't have any choice. I now have a handful of identical .gitconfig files littered around because my tools won't let me specify a single location for it.
Re: After 4.7.3 upgrade, Eclipse thinks my git config is in a different place [message #1784296 is a reply to message #1784221] Mon, 26 March 2018 07:12 Go to previous messageGo to next message
What would you suggest? If the $HOME variable is not set how should (j)git find the users .gitconfig file?
Re: After 4.7.3 upgrade, Eclipse thinks my git config is in a different place [message #1784316 is a reply to message #1784296] Mon, 26 March 2018 12:10 Go to previous messageGo to next message
Well, from the perspective of Eclipse, simply let them specify the location in a config property.
Re: After 4.7.3 upgrade, Eclipse thinks my git config is in a different place [message #1784453 is a reply to message #1784316] Wed, 28 March 2018 03:33 Go to previous message
I think we should find a solution for JGit which is not Eclipse specific. Which of the environment variables HOME, HOMEDRIVE, HOMEPATH, HOMESHARE are set in your environment and how is the system property user.home set in your eclipse. If the code I attached doesn't find enough info in the listed environment variables it will call FS#userHomeImpl(). And this will use the standard system property "user.home". So maybe setting the system property "user.home" in eclipse.ini is sufficient.
Previous Topic:Merging via eclipse
Next Topic:Facing Performance issue with JGIT add command with big repository
Current Time: Sun Jul 20 09:55:36 EDT 2025
Powered by FUDForum. Page generated in 0.27124 seconds
