Home » Modeling » Papyrus » How to design n-ary relations in Papyrus
How to design n-ary relations in Papyrus [message #1784070] Thu, 22 March 2018 05:04 Go to next message
Well as the title says, i would like someone could post an step by step or "mini-how to" in order to include nary relationships in a class diagram using Papyrus.
Also would be nice to add also a association class (if its possible) like date in relation manage in the example below or quantity in the provide association.
Thanks in advance
Some classic examples:
index.php/fa/32409/0/
or
index.php/fa/32410/0/
Example using association class quantity:
index.php/fa/32412/0/
[Updated on: Thu, 22 March 2018 05:26] by Moderator
Re: How to design n-ary relations in Papyrus [message #1784072 is a reply to message #1784070] Thu, 22 March 2018 05:27 Go to previous messageGo to next message
Hi Eduardo,
You should start with a simple binary association, then add "Association branches" to connect the remaining nodes:
index.php/fa/32413/0/
HTH,
Camille
Re: How to design n-ary relations in Papyrus [message #1784074 is a reply to message #1784072] Thu, 22 March 2018 05:32 Go to previous messageGo to next message
Thanks and i suppose to add an association class would be the same ??
Re: How to design n-ary relations in Papyrus [message #1784078 is a reply to message #1784074] Thu, 22 March 2018 05:59 Go to previous messageGo to next message
Association class should be drawn first (Instead of creating a binary Association, you create a Binary AssociationClass). However, it seems that NAry Association Classes don't work well (The diamond is displayed as a square, and the dashed-link from the AssociationClass disappears).
Camille
Re: How to design n-ary relations in Papyrus [message #1784178 is a reply to message #1784078] Fri, 23 March 2018 05:01 Go to previous messageGo to next message
Id try it later....thanks for your answer.... Im supposed to report a bug ? Or it would be some workaround in papyrus devs about this ??
Re: How to design n-ary relations in Papyrus [message #1829286 is a reply to message #1784072] Tue, 30 June 2020 09:37 Go to previous messageGo to next message
Is there a way to put the association's name or label inside the diamond depicting the association on a diagram?
Re: How to design n-ary relations in Papyrus [message #1829319 is a reply to message #1829286] Wed, 01 July 2020 08:42 Go to previous message
no, it is no supported.
Papyrus Team
Previous Topic:Diagram Assistant: Create New Element with stereotype applied
Next Topic:Importing Diagrams as XML/XMI, or EMF, or ...
Current Time: Sat Jul 19 23:23:04 EDT 2025
Powered by FUDForum. Page generated in 0.24834 seconds
