Home » Eclipse Projects » Oomph » Repository Explorer
Repository Explorer [message #1783258] Fri, 09 March 2018 14:25 Go to next message
What is the minimum Oomph software I need to install for Repository Explorer to open repositories?
Currently I install:
Oomph Setup
Oomph Setup UI IDE
With that I get the Repository Explorer view. But it does not successfully open the repository.
In a seperate Eclipse install I install all Oomph software and the Repository Explorer opens repositories successfully.
Thanks.
Re: Repository Explorer [message #1783270 is a reply to message #1783258] Sat, 10 March 2018 02:04 Go to previous messageGo to next message
I think org.eclipse.oomph.p2 is the minimum feature. Perhaps you're just missing some parts of the platform's p2 support. Many things are injected by services so direct dependencies might not pull them in. If something is failing, does the Error log give clues?
Re: Repository Explorer [message #1783496 is a reply to message #1783270] Tue, 13 March 2018 12:15 Go to previous message
Installed Oomph Setup SDK and now the Repository Explorer works. Not sure this is the best solution but it should be sufficient for my needs. Thanks.
Previous Topic:Generate .setup from an existing project
Next Topic:How to use the existing *.target file in oomph setup file
Current Time: Sun Jul 20 18:39:06 EDT 2025
Powered by FUDForum. Page generated in 0.03491 seconds
