Home » Eclipse Projects » Eclipse Titan » Is Neon still required for Titan Eclipse plugin?
Is Neon still required for Titan Eclipse plugin? [message #1783127] Thu, 08 March 2018 04:02 Go to next message
Dear Titan Community,
I am planning to use Titan Designer & Executor Eclipse Plugin together with Papyrus UML editor.
Due to some issues with guava version on Neon (Titan Plugins requires version 21), I migrated to an Oxygen version of Eclipse & Papyrus.
The Titan Eclipse Plugin seems to work fine but I would like to ask if Eclipse 4.6.1 Neon is still the recommended version? (as written in Titan Installation Guide)
Many thanks and regards,
Xavier
Re: Is Neon still required for Titan Eclipse plugin? [message #1783128 is a reply to message #1783127] Thu, 08 March 2018 04:15 Go to previous message
Hi Xavier,
we are also testing Oxygen and it looks fine;
I'd say that Neon is the minimum requirement, it's not recommended to use earlier Eclipse versions.
So you should be OK with Oxygen.
Best regards
Elemer
Previous Topic:Graduation notice
Next Topic:Porting the ETSI IPv6 test suite to Titan part II
Current Time: Sat Jul 19 06:28:54 EDT 2025
Powered by FUDForum. Page generated in 0.08023 seconds
