Home » Eclipse Projects » Kura » The modbus library (org.eclipse.kura.protocol.modbus.ModbusProtocolDeviceService)
The modbus library [message #1782943] Mon, 05 March 2018 08:50 Go to next message
Hii guys,
I wanted to run the modbus example in this link:
https://github.com/eclipse/kura/blob/KURA_3.1.0_RELEASE/kura/examples/org.eclipse.kura.demo.modbus/src/main/java/org/eclipse/kura/demo/modbus/ModbusExample.java
but I had the error that the
org.eclipse.kura.protocol.modbus cannot be resolved
The modbus is no longer supported or do I need to install an external library ??
Please help me
PS: I am using Kura 3.1.1
[Updated on: Mon, 05 March 2018 08:51] by Moderator
Re: The modbus library [message #1782944 is a reply to message #1782943] Mon, 05 March 2018 08:53 Go to previous messageGo to next message
as the message said, you need to install the org.eclipse.kura.protocol.modbus implementation whose code can be found here: https://github.com/eclipse/kura/tree/develop/kura/org.eclipse.kura.protocol.modbus
Matteo
Re: The modbus library [message #1782945 is a reply to message #1782944] Mon, 05 March 2018 08:56 Go to previous messageGo to next message
Thank you very much dear Matteo
Re: The modbus library [message #1782946 is a reply to message #1782944] Mon, 05 March 2018 08:56 Go to previous messageGo to next message
Re: The modbus library [message #1783003 is a reply to message #1782944] Tue, 06 March 2018 06:42 Go to previous messageGo to next message
Dear Matteo,
I've tried many times to run the example but no graphical interface appeared the Kura,
The example is not compatible with KURA 3.1.1 ??
I have attached the log file and the project files, can you please help me ?
Re: The modbus library [message #1783006 is a reply to message #1783003] Tue, 06 March 2018 07:22 Go to previous messageGo to next message
I believe that the bundles seem to be correct, but the first lines of the log you posted show an error with the component. Maybe solving that makes your bundle work.
Matteo
Re: The modbus library [message #1783015 is a reply to message #1783006] Tue, 06 March 2018 09:16 Go to previous messageGo to next message
Dear Matteo,
Thank you very much for your help and support.
I solved the first log problem, it was duplicated component build, so I had to edit the build file.
However the application still didn't appear in Kura Web Interface.
The only exception left is the MQTT one.
Can you please check the log file and help me to detect what's wrong ?
I really appreciate your time and help.
Kindest regards
Ahmed
  • Attachment: modbusLog2
    (Size: 37.76KB, Downloaded 166 times)
Re: The modbus library [message #1783392 is a reply to message #1783015] Mon, 12 March 2018 10:58 Go to previous message
What do you see accessing the OSGi console? what is the result of the "ss" and "ls" commands?
Matteo
Previous Topic:Is the Kura platform officially supported on Windows or not?
Next Topic:Command Service
Current Time: Sun Jul 20 18:45:49 EDT 2025
Powered by FUDForum. Page generated in 0.04252 seconds
