Home » Eclipse Projects » Eclipse Titan » RAW coder and arrays in records
RAW coder and arrays in records [message #1782722] Wed, 28 February 2018 08:12 Go to next message
I'm a bit puzzled on how to use an array of one record in another record without loosing the ability to use the RAW codec:
module PCUIF_Proto {
type record PCUIF_InfoTrx {
        uint16_t        arfcn,
        BIT8            pdch_mask,
        OCT1            spare,
        OCT8            tsc,
        uint32_t        hLayer1
} with { variant "" };
type record PCUIF_info_ind {
        uint32_t        version,
        PCUIF_Flags     flags,
        PCUIF_InfoTrx trx[8],
} with { encode "RAW" };
will fail to compile with titan 6.3.0, while titan claiming that PCUIF_info_ind cannot be encoded as RAW. However, when removing the array it can.
What am I missing here? If the size / encoding of an array element is known, why is the size/encoding of an array of those elements not known? What should I do to make the RAW codec understand this? Thanks!
Re: RAW coder and arrays in records [message #1782723 is a reply to message #1782722] Wed, 28 February 2018 08:26 Go to previous messageGo to next message
The arrays are not supported by the RAW encoder.
Try to use record of with a fixed length
Re: RAW coder and arrays in records [message #1782725 is a reply to message #1782722] Wed, 28 February 2018 08:44 Go to previous messageGo to next message
Hi Harald,
the RAW codec was not extended to arrays, see refguide
4.34 4.23 RAW Encoder and Decoder
You can use the encoding rules defined in this section to encode and decode the following TTCN3 types:
• bitstring
• boolean
• charstring
• enumerated
• float
• hexstring
• integer
• octetstring
• record
• record of, set of
• set
• union
• universal charstring
(no array here)
The why is lost in the depths of time, but I suspect it has to do with the fact
that arrays are not so much useful and they can be replaced with "record of" structures.
So I suggest you try the same:
        uint16_t        arfcn,
        BIT8            pdch_mask,
        OCT1            spare,
        OCT8            tsc,
        uint32_t        hLayer1
type record length(8)  of PCUIF_InfoTrx RecOfPCUIF_InfoTrx ;
        uint32_t             version,
         PCUIF_Flags     flags,
       // PCUIF_InfoTrx trx[8]
        RecOfPCUIF_InfoTrx trx
should give you the desired encoding.
I hope this helps
BR
Elemer
Re: RAW coder and arrays in records [message #1782728 is a reply to message #1782725] Wed, 28 February 2018 09:27 Go to previous messageGo to next message
Hi Elemer,
thanks for the quick help with a work-around. Seems to compile fine at least so far, I hence expect that the encoding also matches expectations.
Re: RAW coder and arrays in records [message #1782786 is a reply to message #1782722] Thu, 01 March 2018 06:40 Go to previous message
The reason is that historically arrays were not allowed to be used within TTCN-3 type definitions.
But this is no longer the case as CL v4.9.1 considers array type definitions to be equivalent to record of type definitions.
Previous Topic:LibCommon compilanion issue
Next Topic:Porting the ETSI IPv6 test suite to Titan part I
Current Time: Sun Jul 20 13:04:32 EDT 2025
Powered by FUDForum. Page generated in 0.24522 seconds
