Code coverage for Xtend (outside of maven build) [message #1782462] |
Fri, 23 February 2018 11:48  |
I'm using jacoco to get code coverage reports. With Eclemma I can run a test with code coverage manually to get markup in the Java editor. All this works fine for Java code that is generated from xtend code.
I found a blog post https://christiandietrich.wordpress.com/2016/01/12/code-coverage-for-xtend/ that describes how to get the markup in xtend, but that works only when running a maven build. Is there a way to get colored markup in the xtend editor after running a test manually? I can't see any preferences in eclipse that correspond to the configuration settings for the xtend-maven-plugin described in the blog post.
Re: Code coverage for Xtend (outside of maven build) [message #1841951 is a reply to message #1782627] |
Fri, 04 June 2021 02:51   |
I know this is very old, but there is a solution.
(Working code, but could be cleaned up).
import java.util.List;
import java.util.Optional;
import javax.inject.Inject;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IWorkspaceRoot;
import org.eclipse.core.runtime.IAdapterFactory;
import org.eclipse.eclemma.core.CoverageTools;
import org.eclipse.eclemma.internal.core.analysis.JavaElementCoverageAdapterFactory;
import org.eclipse.emf.common.util.URI;
import org.eclipse.jdt.core.ICompilationUnit;
import org.eclipse.jdt.core.IJavaElement;
import org.eclipse.jdt.core.JavaCore;
import org.eclipse.ui.IFileEditorInput;
import org.eclipse.xtext.ui.generator.IDerivedResourceMarkers;
import org.jacoco.core.analysis.ICoverageNode;
@SuppressWarnings("restriction")
public class JavaElementAdapterFactory implements IAdapterFactory {
@Inject
private IDerivedResourceMarkers derivedResourceMarkers;
@Inject
private IWorkspaceRoot wsRoot;
public <T> T getAdapter(final Object adaptableObject, final Class<T> adapterType) {
if (adaptableObject instanceof IFileEditorInput && adapterType == IJavaElement.class) {
final IFileEditorInput input = (IFileEditorInput) adaptableObject;
try {
final List<IFile> resources = derivedResourceMarkers.findDerivedResources(wsRoot,
URI.createPlatformResourceURI(input.getFile().getFullPath().toString(), true).toString());
if (!resources.isEmpty()) {
final String fileName = input.getAdapter(IFile.class).getFullPath().removeFileExtension()
.lastSegment()
+ ".java";
final Optional<IFile> file = resources.stream()
.filter(r -> r.getName().equals(fileName))
.findFirst();
if (file.isPresent()) {
return adapterType.cast(JavaCore.create(file.get()));
} catch (final Exception e) {
// ignore
if (adaptableObject instanceof ICompilationUnit && adapterType == ICoverageNode.class) {
final ICoverageNode coverageInfo = (ICoverageNode) new JavaElementCoverageAdapterFactory()
.getAdapter(adaptableObject, adapterType);
if (coverageInfo != null && coverageInfo.containsCode()) {
return adapterType.cast(coverageInfo);
final ICompilationUnit unit = (ICompilationUnit) adaptableObject;
return adapterType
.cast(CoverageTools.getCoverageInfo(unit.getType(unit.getElementName().replace(".java", ""))));
return null;
public Class<?>[] getAdapterList() {
return new Class<?>[] { IFileEditorInput.class, ICompilationUnit.class };
This must be registered via an extension point:
<extension
point="org.eclipse.core.runtime.adapters">
<factory
adaptableType="org.eclipse.ui.IFileEditorInput"
class="com.company.JavaElementAdapterFactory">
<adapter
type="org.eclipse.jdt.core.IJavaElement">
</adapter>
</factory>
<factory
adaptableType="org.eclipse.jdt.core.ICompilationUnit"
<adapter
type="org.jacoco.core.analysis.ICoverageNode">
</adapter>
</factory>
</extension>
and additionally if using custom shortcuts, mode "coverage" needs to be added to these shortcuts.
<extension
point="org.eclipse.debug.ui.launchShortcuts">
<shortcut
label="My test"
helpContextId="org.eclipse.jdt.junit.launch_shortcut"
class="com.company.TestLaunchShortcut"
modes="debug,run,coverage"
id="com.company.debugLaunchShortCutProject">
Some UI widgets don't work this way, this can perhaps be improved. But you get the idea to go forward. Highlighting works in every xtext editor.
FUDForum. Page generated in 0.03946 seconds
