NullpointerException in Workbench [message #1782435] |
Fri, 23 February 2018 08:30 |
I noticed a backround NPE in our application, I did not understand.
I managed to reproduce it with a simple application
(Just launch it and click the button, you will see the NPE in console)
It occurs when runnable used with jface progressmonitor dialog do something that fire an event in equinox registry.
In ProgressInfoItem 186, Display.getCurrent return null.
If I execute the same code inside an Eclipse Job, the NPE does not occurs, Display.getCurrent return the display, not null.
I do not understand yet, why it behaves differently between Job and ProgressDialog.
Anyway, according to comment above (and bug 341816) it seems here Display.getDefault could be used instead, unless I missed something and do something illegal in the code.
The exception:
at org.eclipse.ui.internal.progress.ProgressInfoItem.init(ProgressInfoItem.java:186)
at org.eclipse.ui.internal.progress.ProgressManager$ProgressManagerProvider.getInstance(ProgressManager.java:105)
at org.eclipse.ui.internal.progress.ProgressManager.getInstance(ProgressManager.java:187)
at org.eclipse.rap.ui.internal.progress.JobManagerAdapter$3.run(JobManagerAdapter.java:189)
at org.eclipse.rap.rwt.internal.lifecycle.ContextUtil.runNonUIThreadWithFakeContext(ContextUtil.java:67)
at org.eclipse.rap.rwt.internal.service.UISessionImpl.exec(UISessionImpl.java:246)
at org.eclipse.rap.ui.internal.progress.JobManagerAdapter.findSessionProgressManager(JobManagerAdapter.java:187)
at org.eclipse.rap.ui.internal.progress.JobManagerAdapter.findProgressManager(JobManagerAdapter.java:175)
at org.eclipse.rap.ui.internal.progress.JobManagerAdapter.scheduled(JobManagerAdapter.java:161)
at org.eclipse.core.internal.jobs.JobListeners.doNotify(JobListeners.java:70)
at org.eclipse.core.internal.jobs.JobListeners.scheduled(JobListeners.java:125)
at org.eclipse.core.internal.jobs.JobManager.schedule(JobManager.java:1257)
at org.eclipse.core.internal.jobs.InternalJob.schedule(InternalJob.java:382)
at org.eclipse.core.runtime.jobs.Job.schedule(Job.java:635)
at org.eclipse.core.internal.registry.osgi.EquinoxRegistryStrategy.scheduleChangeEvent(EquinoxRegistryStrategy.java:86)
at org.eclipse.core.internal.registry.ExtensionRegistry.fireRegistryChangeEvent(ExtensionRegistry.java:278)
at org.eclipse.core.internal.registry.ExtensionRegistry.add(ExtensionRegistry.java:129)
at org.eclipse.core.internal.registry.ExtensionRegistry.addContribution(ExtensionRegistry.java:1085)
at org.eclipse.core.internal.registry.ExtensionRegistry.addContribution(ExtensionRegistry.java:1040)
at org.eclipse.core.internal.registry.osgi.EclipseBundleListener.addBundle(EclipseBundleListener.java:181)
at org.eclipse.core.internal.registry.osgi.EclipseBundleListener.bundleChanged(EclipseBundleListener.java:79)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:719)
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:511)
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:457)
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:447)
at org.eclipse.osgi.container.Module.start(Module.java:427)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402)
FUDForum. Page generated in 0.23909 seconds
