Home » Newcomers » Newcomers » Could not connect to virtual machine(Problem when installing the Java ME environment)
Could not connect to virtual machine [message #1782161] Mon, 19 February 2018 12:43
I have just installed the Java Me environment on the Eclipse IDE (Oxygen).
However, when trying to run a simple test Midlet the following message is received:
could not connect with the virtual machine.
It seems the installation is not really well done.
The java -version command produces the enclosed result:
java version "9.0.4"
Java(TM) SE Runtime Environment (build 9.0.4+11)
Java HotSpot(TM) 64-Bit Server VM (build 9.0.4+11, mixed mode)
Any idea on how to solve it?
Previous Topic:Unable to connect to updates repositories
Next Topic:Setting breakpoints in Javascript editor does not work as expected
Current Time: Sun Jul 20 04:24:45 EDT 2025
Powered by FUDForum. Page generated in 0.07201 seconds
