Home » Newcomers » Newcomers » Android requires compiler compliance level 5.0 or 6.0. Found '1.8' instead(Developing Android application in Eclipse w/ Java 8)
Android requires compiler compliance level 5.0 or 6.0. Found '1.8' instead [message #1781246] Sun, 04 February 2018 16:56
I am developing an Android application using Eclipse.
Eclipse IDE for Java Developers
Version: Oxygen.2 Release (4.7.2)
Build id: 20171218-0600
OS: Linux, v.4.9.0-4-amd64, x86_64 / gtk 3.22.11, WebKit 2.16.6
In Window/Preferences:
Java/Complier
Java compliance level ----> 1.8
Installed JREs - java-8-openjdk-amd64
When I set in my project properties the Java compiler entry to 1.8, and attempt to build the project, the build fails with the following message:
"Android requires compiler compliance level 5.0 or 6.0. Found '1.8' instead. Please use Android Tools > Fix Project Properties."
This happens regardless of the Android settings in project properties.
When I build the same project using Android Studio, there is no problem with the build (but I have other issues).
I would appreciate feedback about this, and ideas about a possible resolution. I need to use Java 8.
Thanks in advance,
Alex Donnini
Previous Topic:trouble upgrading oxygen, rolls back to neon 3?
Next Topic: JavaScript editor
Current Time: Sun Jul 20 07:43:17 EDT 2025
Powered by FUDForum. Page generated in 0.09166 seconds
