Home » Modeling » Graphiti » Drag & Drop IFile object from Project Explorer into Graphiti Editor(Drag & Drop IFile object from Project Explorer into Graphiti Editor)
Drag & Drop IFile object from Project Explorer into Graphiti Editor [message #755321] Tue, 08 November 2011 01:32 Go to next message
I wish to drag & drop a IFile [ actually a XML file ] object from project explorer onto Graphiti Editor, which results in creation of a new Node with properties taken from the XML file. I thought of using getDragandDropFeatures in the FeatureProvider class, but it doesn't work.
Please suggest with an example how a file object can be dragged & dropped into Graphiti editor which results in any custom action.
Kunal
Re: Drag & Drop IFile object from Project Explorer into Graphiti Editor [message #755363 is a reply to message #755321] Tue, 08 November 2011 04:35 Go to previous messageGo to next message
Hi Kunal,
if you DnD a IFile into a Graphiti editor, this calls the getAddFeature in your feature provider implementation. There you can handle the case, that the new object is of type IFile and then load its contents as EMF resource to be able to query the model objects. The getDragAndDropFeatures have not to be overridden, this is just used for DnD connection lines.
	public IAddFeature getAddFeature(IAddContext context) {
		IAddFeature feature = null;
		if (context.getNewObject() instanceof IFile) {
Joerg
Re: Drag & Drop IFile object from Project Explorer into Graphiti Editor [message #1780908 is a reply to message #755363] Mon, 29 January 2018 16:34 Go to previous message
Looks like I am resurrecting an old discussion...
I am trying to DND an file from a view onto a Graphiti Editor. This works if the view is a Package Explorer - I DND a file and getAddFeature() method gets called, but does not work when I try to DND from a View, class of which extends ResourceNavigator. Is there something that should be done on View side in order for DND to work? An extension point that needs to be implemented?
Previous Topic:How to modify the default behavior of draw connection?
Next Topic:Graphiti and RAP
Current Time: Sat Jul 19 11:14:37 EDT 2025
Powered by FUDForum. Page generated in 0.25429 seconds
