Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » JAVA for version 1.9.x
JAVA for version 1.9.x [message #1780766] Fri, 26 January 2018 12:53 Go to next message
Formerly it was so that version 1.6.x needed JAVA 6, version 1.7.x JAVA 7 a.s.o. This seems not to be the case with 1.9.x or at least according to the download page. I did test with zulu-9 and it failed big time but with zulu-8 it seems to be running or at least it hasn't failed yet.
How will it be with future releases?
Re: JAVA for version 1.9.x [message #1780773 is a reply to message #1780766] Fri, 26 January 2018 15:46 Go to previous messageGo to next message
You identified here an interesting coincidence. But the reason for upgrading to newer Java versions was sofar requirements of used Eclipse libraries. Currently i don't expect an update to Java 9. but In the case it will happen we'll announce it upfront to the release.
Re: JAVA for version 1.9.x [message #1780812 is a reply to message #1780773] Sun, 28 January 2018 08:34 Go to previous message
on the download pages it is stated that 4diac requires java 8. as long as this information is not updated, java 9 can only be used to your own responsibility.
Previous Topic:Problem with FBRT
Next Topic:Forte build size
Current Time: Sat Jul 19 22:29:42 EDT 2025
Powered by FUDForum. Page generated in 0.49296 seconds
