Home » Newcomers » Newcomers » Subclipse problem(Subversion update raises the processor ocupancy to 100%.)
Subclipse problem [message #1779792] Fri, 12 January 2018 11:48 Go to next message
I had installed Eclipse Java EE IDE for Web Developers version Oxygen.2 Release (4.7.2) and Subclipse from Eclipse Marketplace.
I can open and work on my projects normally, but when I try to update from a Subversion repository, the processor ocupancy raise to 100% for 10 minutes, and then Eclipse closes. (Also, the hard disk activity raises.)
(My operationg system is openSuse Leap 42.3. I can connect to Subversion repository by mean other applications, like "kdesvn".)
I checked the log file in "workspace/.metadata/.log", but I didn't find anythig relevant.
Is there another log file to check?
Can somebody help me to resolv this problem?
I'll appreciate your help.
Re: Subclipse problem [message #1779817 is a reply to message #1779792] Sat, 13 January 2018 03:08 Go to previous messageGo to next message
I would try to increase the heap size as a first try: https://wiki.eclipse.org/FAQ_How_do_I_increase_the_heap_size_available_to_Eclipse%3F
Subclipse is hosted at https://github.com/subclipse/subclipse so perhaps you can open an issue to ask about this problem there.
Re: Subclipse problem [message #1779859 is a reply to message #1779817] Sun, 14 January 2018 18:18 Go to previous message
The problem seems to be every time Eclipse (or Subversion) wants to open "kdewallet" in order to get repository password.
Eclipse print the following in a terminal:
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
kbuildsycoca4 running...
QDBusConnection: name 'org.kde.kwalletd' had owner '' but we thought it was ':1.45'
(When I don't save repository password, Subclipse work normally.)
Thank you very much.
Previous Topic:Internal Error occured during " launching SampleTest.java" TestNG class
Next Topic:Éclipse lite configuration
Current Time: Sun Jul 20 16:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.07953 seconds
