Kura 3.1.0, Raspi3, Sensortag connectivity Problem [message #1779535] |
Tue, 09 January 2018 06:30  |
Hi, thanks in advance for any help.
I am trying to connect the sensortag 2650 to my raspberry Pi3.
Environment is:
Kura 3.1.0
bluetoothctl --version 5.43
org.eclipse.kura.driver.ble.sensortag driver installed
org.eclipse.kura.example.ble.tisensortag.tinyb Kura interface installed
getting the following errors in /var/log/kura.log
2018-01-09 19:15:06,312 [pool-18-thread-1] ERROR o.e.k.e.b.t.t.BluetoothLe - Scan for devices failed
2018-01-09 19:15:12,027 [pool-24-thread-1] ERROR o.e.k.e.b.t.t.TiSensorTag - Connection failed
2018-01-09 19:15:17,047 [pool-24-thread-1] ERROR o.e.k.e.b.t.t.TiSensorTag - Failed to get GATT service
When i check the bluetooth interface using sudo hcitool lescan, it is UP
Would appreciate any pointers TQ.
Re: Kura 3.1.0, Raspi3, Sensortag connectivity Problem [message #1780068 is a reply to message #1779965] |
Tue, 16 January 2018 23:28  |
Hi Pier,
thanks for your help as now it is partially working!
the sensortag green led is blinking when kura was trying to connect to the device. I removed the battery on the sensortag and reinserted and now it works in that kura.log reports the values are being read from the sensortag.
However, in the "Drivers and Assets" section of the Kura web page, when i try to read the device Data I get an "org.eclipse.kura.web.client.ui.EntryClassUi: A generic unrecoverable error happened. Please refer to the device log"
kura.log has the below
org.eclipse.kura.KuraBluetoothDiscoveryException: Error during discovery procedure.
at org.eclipse.kura.internal.ble.BluetoothLeAdapterImpl$BluetoothFuture.run(BluetoothLeAdapterImpl.java:232)
... 1 more
2018-01-16 20:22:05,862 [qtp23450296-108] WARN o.e.k.i.d.b.s.SensorTagDriver - SensortTag Read Operation Failed
2018-01-16 20:22:10,831 [Thread-489] ERROR o.e.k.i.b.BluetoothLeAdapterImpl - Stop discovery failed
tinyb.BluetoothException: GDBus.Error:org.bluez.Error.Failed: No discovery started
at tinyb.BluetoothAdapter.stopDiscovery(Native Method)
at org.eclipse.kura.internal.ble.BluetoothLeAdapterImpl$BluetoothFuture.run(BluetoothLeAdapterImpl.java:249)
at java.lang.Thread.run(Thread.java:745)
2018-01-16 20:22:10,834 [Thread-490] ERROR o.e.k.i.b.BluetoothLeAdapterImpl - Stop discovery failed
the sensortag data like temperature etc is being written to the log so the problem is now on the "UI" level data discovery.
So almost there!....any pointers on this?
rgds adrian
[Updated on: Wed, 17 January 2018 00:30] by Moderator
FUDForum. Page generated in 0.04806 seconds
