Home » Newcomers » Newcomers » HTTP/2 support with Jetty(Adding HTTP/2 package of Jetty)
HTTP/2 support with Jetty [message #1779498] Mon, 08 January 2018 13:27 Go to next message
I was wondering if a support for HTTP/2 with Jetty is planned for http://download.eclipse.org/eclipse/updates/4.7-M-builds/?
By checking : http://download.eclipse.org/eclipse/updates/4.7-M-builds/M-4.7.2RC4-201711300510/
I noticed that it includes HTTP/1.1 package of Jetty 9.4.7. but not HTTP/2. If it is not planned, who should I contact to ask to add it?
Thank you
Re: HTTP/2 support with Jetty [message #1779546 is a reply to message #1779498] Tue, 09 January 2018 08:32 Go to previous message
HTTP/2 support requires a -XBootclasspath entry to add the required ALPN support layer to the TLS implementation found in the OpenJDK JVM.
This alpn-boot.jar is highly OpenJDK/JVM specific and you must use a specific version of alpn-boot.jar for each specific version of the OpenJDK/JVM you are using.
This -XBootclasspath requirement for ALPN also only works with OpenJDK, it is not supported on any other JVM (eg: IBM).
This -XBootclasspath requirement goes away with JDK9+.
It's unlikely to see Eclipse supporting JVM neutral HTTP/2 at this point in time, unless Eclipse 4.7 wants to go with JDK9+ as a minimum requirement.
Previous Topic:Jetty server crashes
Next Topic:Jetty 8 Virtual Host
Current Time: Sat Jul 19 21:43:47 EDT 2025
Powered by FUDForum. Page generated in 0.06958 seconds
