Home » Archived » BIRT » Problem with Legend in Graphs(When all data is in one direction, bar and pie show only one legend item.)
Problem with Legend in Graphs [message #1779057] Sun, 31 December 2017 07:32 Go to next message
Should show both legend items (even if one is not present in the chart)
How can this be fixed?
This is how it looks OK:
index.php/fa/31702/0/
This is how it looks WRONG:
index.php/fa/31701/0/
Attached are project files (I tried to delete most of the irrelevant code).
creatirea is: <amad>
either:
<amad>1</amad>
ot:
<amad>0</amad>
Hope this is clear and someone has a solution for this.
Many thanks
Yosi
Re: Problem with Legend in Graphs [message #1779671 is a reply to message #1779057] Wed, 10 January 2018 22:06 Go to previous message
Hi there. You probably need to build your data so you always have the series present even if there is no data for it.
for example, create a reference table that contains the values 'Right' and 'Wrong', then in your main query do an outer join based on the reference table so you always end up with a row for each category regardless of whether there is any data.
FWIW - I am an BIRT n00b, but I know a bit about SQL. The problem you are describing is a classic in SQL (for example, how do I make a query return sales per week even when there are no sales in a particular week. The easiest answer - use a reference table of weeks).
Previous Topic:BIRT datetime function
Next Topic:Emitter in BIRT Runtime
Current Time: Sun Jul 20 17:51:32 EDT 2025
Powered by FUDForum. Page generated in 0.03710 seconds
