Unhandled event loop exception with WindowBuilder [message #1777372] |
Tue, 28 November 2017 20:06  |
I get unhandled event loop exception when I switch to design view. The stack trace is below. This worked in ubuntu 16.10, but gives the error in 17.10 and Antergos (Arch-based). It seems to be related to having menu widgets, as simple dialogs don't see the failure. I would welcome any pointers on how to figure this out or work around it. This is with Eclipse Oxygen.
at org.eclipse.wb.internal.core.editor.UndoManager.addSelectionListener(UndoManager.java:187)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:382)
at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:263)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:241)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5268)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1348)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1374)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1357)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1142)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3187)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1870)
at org.eclipse.swt.custom.CTabFolder.lambda$0(CTabFolder.java:328)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4522)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4107)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
FUDForum. Page generated in 0.03721 seconds
