Home » Newcomers » Newcomers » Automatic save - how to disable
Automatic save - how to disable [message #1777199] Sun, 26 November 2017 21:27 Go to next message
I have enabled Automatic save before compile AFTER I make changes in any source file.
It quit working.
Now I have to "Close project" to get the dialogue to manually save the changes.
How do I disable the not working autosave so I do not have to do this close / open / build project.
AKA I need to save changes manually before doing Build.
Re: Automatic save - how to disable [message #1777221 is a reply to message #1777199] Mon, 27 November 2017 03:28 Go to previous messageGo to next message
There is File -> Save All which has Ctrl-Shift-S as a shortcut, so surely you don't need to close and open projects? Which language is involved? Which option exactly is involved here? I only know about Window -> Preferences -> General -> Editors -> Autosave but that has nothing specifically to do with saving before a compile but rather saving after a period of inactivity...
Re: Automatic save - how to disable [message #1777243 is a reply to message #1777221] Mon, 27 November 2017 07:49 Go to previous message
Thanks for reply.
I am aware of "Save all", my question is how to RE ENABLE "automatic save"
So actually the title of my post is misleading - sorry.
Using C++ (Oxygen) on Ubuntu if that helps.
This "automatic save" popped up every time I would select "Run" AFTER I made changes in source.
The initial dialogue has an option to be bypassed and all changed sources will be saved automatically then "Run " will commence. I selected that option and it worked.
The dialogue was no longer activated - naturally - no need to be.
After making another copy of my project it no longer works - so I was just curious how to get back to that dialogue and possibly activate this auto save again.
Maybe I need to build a New Project instead of using copy . I'll give it a go if it works.
Previous Topic:Eclipse Oxygen crashes when trying to create Liferay Workspace or Module
Next Topic:CSS Grid support
Current Time: Sat Jul 19 15:43:38 EDT 2025
Powered by FUDForum. Page generated in 0.08831 seconds
