Home » Newcomers » Newcomers » Eclipse Oxygen - Memory consumption on MAC(Eclipse seem to consume lot of memory over a period of time (viz. if I use for 5 or 6 hours))
Eclipse Oxygen - Memory consumption on MAC [message #1776886] Wed, 22 November 2017 09:12 Go to next message
I have seen eclipse consuming lot of memory. At times it is even more than 1.5 Gig.
I have set up Java parameters in eclipse.ini as:
-XX:MaxPermSize=256m
-XX:MaxMetaspaceSize=256m
-Xms256m
-Xmx1024m
Any clues if there is any other parameter which I can use to cap it to about 1 Gig (or less)
Re: Eclipse Oxygen - Memory consumption on MAC [message #1776905 is a reply to message #1776886] Wed, 22 November 2017 11:31 Go to previous messageGo to next message
Your question doesn't really make sense. There is no way to force less memory to be used than is actually needed, and you've said nothing about what you're actually doing. The best you can hope accomplish is to have the Eclipse IDE die/terminate because no more objects can be allocated in the heap limit you've set, and that seems far less than helpful. Some of the applications I work with require heap sizes of 5g or more simply because the data being manipulated needs that much space....
Re: Eclipse Oxygen - Memory consumption on MAC [message #1776907 is a reply to message #1776905] Wed, 22 November 2017 11:42 Go to previous messageGo to next message
Typically have work on Java projects.
- eGit client to sync code
- Occasionally use eclipse debugger to debug / step thro' the code.
I usually memory usage increasing when remote debugging, HOWEVER it does not release the memory back when I stop debugging ..etc ..
Re: Eclipse Oxygen - Memory consumption on MAC [message #1776949 is a reply to message #1776907] Thu, 23 November 2017 02:47 Go to previous message
If there is a reproducible memory leak, you'll need to open a Bugzilla report with a precise description of how to reproduce the problem. No JVM option will fix such a problem.
Previous Topic:stdin in Run configuration failed to detect EOF on Linux
Next Topic:eclipse oxygen setup installation exceptions
Current Time: Sun Jul 20 07:17:46 EDT 2025
Powered by FUDForum. Page generated in 0.10699 seconds
