Home » Modeling » TMF (Xtext) » Debugging DSL Instances
Debugging DSL Instances [message #1776715] Mon, 20 November 2017 12:25 Go to next message
I am trying to debug a DSL instance. I have read on several topics that it should be possible to set a breakpoint in the DSL file and it will put the corresponding breakpoint in the transpiled Java.
Right now I cannot set a breakpoint in the DSL instance. The generated plugins work (code completion, scoping, ...) but there is no way of putting a breakpoint.
Similarly I cannot navigate from the DSL code to the generated Java Code.
Could someone point me to what is missing?
Many thanks in advance
[Updated on: Mon, 20 November 2017 12:26] by Moderator
Re: Debugging DSL Instances [message #1776720 is a reply to message #1776715] Mon, 20 November 2017 12:59 Go to previous messageGo to next message
Do you use xbase? Do you use debug trace generator?
Re: Debugging DSL Instances [message #1776723 is a reply to message #1776720] Mon, 20 November 2017 14:44 Go to previous messageGo to next message
Hello thanks for you help.
I use Xtend (which is from my understanding an extension from Xbase) to generate the Java Code. I am looking for more information about debug trace generator.
If I cannot enable debugging I would like at least be able to navigate from dsl code to java code.
Re: Debugging DSL Instances [message #1776724 is a reply to message #1776723] Mon, 20 November 2017 14:48 Go to previous messageGo to next message
No I mean you dsl. Debuggability you will get other only for xbase dsls
Same for go to generated code
If you don't use xbase you need to implement that yourself
Re: Debugging DSL Instances [message #1776725 is a reply to message #1776724] Mon, 20 November 2017 14:49 Go to previous messageGo to next message
Ps have a look at the domainmodel example
Re: Debugging DSL Instances [message #1776726 is a reply to message #1776725] Mon, 20 November 2017 14:51 Go to previous messageGo to next message
For tracing have a look at https://typefox.io/generate-traced-code-with-xtext and the 2.13 release notes
You might need to implement some gluecody yourself
(Copy and paste from xbase)
Cannot give you a complete list of pointers
Re: Debugging DSL Instances [message #1776731 is a reply to message #1776726] Mon, 20 November 2017 15:15 Go to previous message
So no it's not a Xbase DSL, the syntax is completly different and hence xbase was not a good starting point.
Thanks for your help I will start from the link.
[Updated on: Mon, 20 November 2017 15:16] by Moderator
Previous Topic:Xtext web editor is disabled
Next Topic:Xtext web editor is disabled
Current Time: Sat Jul 19 14:28:17 EDT 2025
Powered by FUDForum. Page generated in 0.04775 seconds
