Home » Newcomers » Newcomers » MAVEN with Eclipse Kepler and Galileo(Need to know which Eclipse supports latest MAVEN)
MAVEN with Eclipse Kepler and Galileo [message #1776658] Mon, 20 November 2017 00:44 Go to next message
Hi All,
I need to install MAVEN in Eclipse. But I need to know which Eclipse version is supported for this. Can I download Eclipse Galileo for this or I should stick to any older version?
Kindly help me asap as it's kind of urgent.
Thanks in advance!
Re: MAVEN with Eclipse Kepler and Galileo [message #1776697 is a reply to message #1776658] Mon, 20 November 2017 09:57 Go to previous messageGo to next message
These are ridiculously old version of Eclipse. You should install the latest Eclipse from https://www.eclipse.org/downloads/ and note that this page https://www.eclipse.org/m2e/m2e-downloads.html suggests that the m2e support has been tested for Neon, so I would not assume it will work well for very old versions of Eclipse though I would assume it will work well for Oxygen.
[Updated on: Tue, 21 November 2017 00:19] by Moderator
Re: MAVEN with Eclipse Kepler and Galileo [message #1776747 is a reply to message #1776697] Tue, 21 November 2017 00:26 Go to previous message
Thanks a lot!
Previous Topic:Compiling
Next Topic:Question on backwards compatibility of eclipse 4.x
Current Time: Sun Jul 20 17:30:50 EDT 2025
Powered by FUDForum. Page generated in 0.10440 seconds
