Pragmatically resize a view [message #1776032] |
Thu, 09 November 2017 08:48  |
Question from stackoverflow.com
I'm testing an non-e4 RCP application using SWTBot and I need to change the size of my view. (Move the sash-bar)
I unsuccessfully tried
- Resize my view using SWTBot (no such api)
- Resize my view using Eclipse 3 API (no supported)
- Resize my view using underlying e4 model (resizing not working)
e4 model approach seams to be promising, but I'm missing something, so it doesn't work.
I can
- Get MPart of my view:
view = ePartService.findPart(ID)
- Get MTrimmedWindow:
window = (view as EObject).eContainer as MTrimmedWindow
I can't
- locale correct MPartSashContainer
- move sash-bar with setContainerData()
I would like to know:
- How can I move from MPart to its direct parent (e.g. MPartStack)? (MPart.getParent() returns null for my view)
- Why common EObject methods like eContainer() are not present on M... objects?
Thank you very much in advance!
[Updated on: Thu, 09 November 2017 08:56] by Moderator
Re: Pragmatically resize a view [message #1776525 is a reply to message #1776257] |
Fri, 17 November 2017 04:42  |
Ok, I found a solution myself.
The thing is, that the view is not a part of the e4 UI-Tree. view.eContainer is directly the MWindow. To be placed at the right spot the view is connected to the MPlaceholder, that is a part of the e4 UI-Tree and has getParent() != null.
In order to resize a view the steps are:
- Show view
- Find MPlaceholder of the view
- Find MPartStack and MPartSashContainer object
- Set containerData
- Redraw widget (yes, auto-update seam not to work in this case)
Example:
EModelService modelService = PlatformUI.getWorkbench().getService(EModelService.class);
EPartService partService = PlatformUI.getWorkbench().getService(EPartService.class);
// Show view
IWorkbenchPage page = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
page.showView(MyView.ID, null, IWorkbenchPage.VIEW_ACTIVATE);
MPart view = partService.findPart(MyView.ID);
// view.getParent() => null, because 'view' is not a part of the e4 UI-model!
// It is connected to the Model using MPlaceholder
// Let's find the placeholder
MWindow window = (MWindow)(((EObject)eView).eContainer);
MPlaceholder placeholder = modelService.findPlaceholderFor(window, view);
MUIElement element = placeholder;
MPartStack partStack = null;
while (element != null) {
// This may not suite your configuration of views/stacks/sashes
if (element instanceof MPartStack && ((Object)element.parent) instanceof MPartSashContainer) {
partStack = (MPartStack)element;
break;
element = element.parent;
if (partStack == null) { /* handle error */ }
// Now let's change the width weights
for (MUIElement element : partStack.getParent().getChildren()) {
if (element == partStack) {
element.setContainerData("50"); // Width for my view
} else {
element.setContainerData("25"); // Widths for other views & editors
// Surprisingly I had to redraw tho UI manually
// There is for sure a better way to do it. Here is my (quick & very dirty):
partStack.toBeRendered = false
partStack.toBeRendered = true
Please correct me, if there is a better solution.
What to give me +1? ;)) you can do it here: https://stackoverflow.com/questions/47202032/pragmatically-resize-a-view-in-eclipse/47347113#47347113
[Updated on: Fri, 17 November 2017 04:44] by Moderator
FUDForum. Page generated in 0.05178 seconds
