Home » Newcomers » Newcomers » Where can I find my Tomcat server Error Logs?(Tomcat v7.0 Error logs not created - access logs are created.)
Where can I find my Tomcat server Error Logs? [message #1776517] Fri, 17 November 2017 03:40
I'm totally new to Eclipse and I am trying to create a project based on the Apache Chemistry CMIS project. Every time there is an error, however, I pretty much have to run a debugger through my server code to find where it goes wrong, because I do not have any error logs available. The "Server path" is currently set to:
.metadata/.plugins/org.eclipse.wst.server.core/tmp1
and this is where I can find the access logs. In the web.xml of the server configuration, I have set the debug level to '11' like so:
    <servlet>
        <servlet-name>default</servlet-name>
        <servlet-class>org.apache.catalina.servlets.DefaultServlet</servlet-class>
        <init-param>
            <param-name>debug</param-name>
            <param-value>11</param-value>
        </init-param>
        <init-param>
            <param-name>listings</param-name>
            <param-value>false</param-value>
        </init-param>
        <load-on-startup>1</load-on-startup>
    </servlet>
Is there any other place I should set this debug level?
Tycho
Previous Topic:Complete Environment Export/Import
Next Topic:Eclipse Mars and STM8L052C6T6 with ST-Link/V2
Current Time: Sun Jul 20 16:12:13 EDT 2025
Powered by FUDForum. Page generated in 0.71340 seconds
