Home » Modeling » EMF » [xcore] using "id" as attribute name
[xcore] using "id" as attribute name [message #1776364] Wed, 15 November 2017 12:39 Go to next message
I am trying to implement an existing interface with xcore and I need to have a String attribute called "id".
Something like that:
package sample.model
class User {
    String id
My problem is that "id" seems to be a special keyword in the xcore dsl.
What are the possibilities?
My current solution is a post processing step (after the code generation) where I modify the name of the attribute with text search and replace.
PS: I cannot change the name of the attribute, because it is driven by an interface that my Ecore-Entity needs to implements (very easy to do with xcore, see my post on that topic)
Re: [xcore] using "id" as attribute name [message #1776396 is a reply to message #1776364] Thu, 16 November 2017 02:56 Go to previous messageGo to next message
You can use ^ to "escape" keywords.
package ^package
class Class
	id String ^id
Re: [xcore] using "id" as attribute name [message #1776397 is a reply to message #1776396] Thu, 16 November 2017 03:03 Go to previous message
Thank you a lot!
Previous Topic:[CDO] Security Model, I dont want that user can see all directories
Next Topic:[CDO] Timeout while prefetching
Current Time: Sun Jul 20 16:18:48 EDT 2025
Powered by FUDForum. Page generated in 0.69922 seconds
