Home » Newcomers » Newcomers » Installing Eclipse(Problems Installing Eclipse )
Installing Eclipse [message #1776278] Tue, 14 November 2017 14:48 Go to next message
I installed an additional hard drive on my computer. After I did I made the mistake of moving some programming files and it lost my settings. I uninstalled Eclipse and java. I reinstalled Java and tried to install Eclipse.
I can download the install file eclipse-inst-win64.exe, no matter what I do the installer won't start. I tried to download and extract the files for java and c separately but they won't run.
Is there a hidden file somewhere I need to remove from my computer to be able to run the eclipse installer?
When I click on it, right click and open, or run as administrator nothing happens.
Re: Installing Eclipse [message #1776311 is a reply to message #1776278] Wed, 15 November 2017 04:09 Go to previous messageGo to next message
The installer is a native executable and it reads the registry to find the Java installations on your machine. If you have moved/changed things in your "Program Files" folder, your registry might well be referencing things that don't exist and that could cause problems. The contents of the folder <home>\.eclipse\org.eclipse.oomph.jreinfo contains information about the JREs/JDKs available on your machine. I wonder if it contains entries that reference things you'e destroyed?
Re: Installing Eclipse [message #1776343 is a reply to message #1776311] Wed, 15 November 2017 08:54 Go to previous messageGo to next message
i have a long issue, i instated it previously and it worked, but had a few issues with it so i uninstalled it and reinstalled it and now this shows up
[2017-11-15 07:28:00] Executing bootstrap tasks
[2017-11-15 07:28:00] Java(TM) SE Runtime Environment 1.8.0_151-b12
[2017-11-15 07:28:00] Product org.eclipse.products.epp.package.java.oxygen
[2017-11-15 07:28:00] Bundle org.eclipse.oomph.setup 1.8.0.v20170408-0745, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 07:28:00] Bundle org.eclipse.oomph.setup.core 1.8.0.v20170531-0903, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 07:28:00] Bundle org.eclipse.oomph.setup.p2 1.8.0.v20170318-0419, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 07:28:00] Performing P2 Director (Eclipse IDE for Java Developers (Oxygen))
[2017-11-15 07:28:00] Offline = false
[2017-11-15 07:28:00] Mirrors = true
[2017-11-15 07:28:00] Resolving 24 requirements from 3 repositories to C:\Users\Peg\eclipse\java-oxygen2\eclipse
[2017-11-15 07:28:00] Requirement epp.package.java [4.7.0,4.8.0)
[2017-11-15 07:28:00] Requirement org.eclipse.platform.feature.group [4.7.0,4.8.0)
[2017-11-15 07:28:00] Requirement org.eclipse.rcp.feature.group [4.7.0,4.8.0)
[2017-11-15 07:28:00] Requirement org.eclipse.buildship.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.eclemma.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.egit.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.egit.mylyn.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.jdt.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.jgit.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.m2e.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.m2e.logback.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.context_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.git.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.hudson.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.ide_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.java_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn.wikitext_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.mylyn_feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.recommenders.mylyn.rcp.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.recommenders.rcp.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.recommenders.snipmatch.rcp.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.wst.xml_ui.feature.feature.group
[2017-11-15 07:28:00] Requirement org.eclipse.oomph.setup.feature.group
[2017-11-15 07:28:00] Repository http://download.eclipse.org/technology/epp/packages/oxygen
[2017-11-15 07:28:00] Repository http://download.eclipse.org/releases/oxygen
[2017-11-15 07:28:00] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2017-11-15 07:28:01] ERROR: org.eclipse.equinox.p2.metadata.repository code=1002 Unable to read repository at http://download.eclipse.org/releases/oxygen.
ERROR: org.eclipse.equinox.p2.repository code=0 An error occurred while downloading http://download.eclipse.org/technology/epp/packages/oxygen/content.xml.xz. The cache file C:\Users\Peg\.p2\org.eclipse.equinox.p2.repository\cache\downloading\-1747184149 could not be renamed to C:\Users\Peg\.p2\org.eclipse.equinox.p2.repository\cache\-1747184149.
at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:428)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCacheFromFile(CacheManager.java:132)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.getLocalFile(XZedSimpleMetadataRepositoryFactory.java:56)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.load(XZedSimpleMetadataRepositoryFactory.java:78)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:117)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:409)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:201)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:476)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:166)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:106)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:122)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoader$Worker.perform(ProfileTransactionImpl.java:1613)
at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:428)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
i would be so grateful if anyone could help
Re: Installing Eclipse [message #1776352 is a reply to message #1776343] Wed, 15 November 2017 09:51 Go to previous messageGo to next message
Problems such as this are typically caused by a virus scanner locking files (for a very short time), making attempts to move/rename them fail. Typically such things will be timing dependent and might fail only sporadically. On my machine I've configured the virus scanner not to scan things in my .eclipse and .p2 folders.
Re: Installing Eclipse [message #1776371 is a reply to message #1776352] Wed, 15 November 2017 13:23 Go to previous messageGo to next message
okay, I made the folder to be ignored by windows defender... i like to live life dangerously and dont really have much for anti virus...
new error message though
[2017-11-15 12:17:53] Executing bootstrap tasks
[2017-11-15 12:17:53] Java(TM) SE Runtime Environment 1.8.0_151-b12
[2017-11-15 12:17:53] Product org.eclipse.products.epp.package.java.oxygen
[2017-11-15 12:17:53] Bundle org.eclipse.oomph.setup 1.8.0.v20170408-0745, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 12:17:53] Bundle org.eclipse.oomph.setup.core 1.8.0.v20170531-0903, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 12:17:53] Bundle org.eclipse.oomph.setup.p2 1.8.0.v20170318-0419, build=3059, branch=2161405b80cf99ed791602ba56cdf44084f5ca43
[2017-11-15 12:17:53] Performing P2 Director (Eclipse IDE for Java Developers (Oxygen))
[2017-11-15 12:17:53] Offline = false
[2017-11-15 12:17:53] Mirrors = true
[2017-11-15 12:17:53] Resolving 24 requirements from 3 repositories to C:\Users\Peg\eclipse\java-oxygen\eclipse
[2017-11-15 12:17:53] Requirement epp.package.java [4.7.0,4.8.0)
[2017-11-15 12:17:53] Requirement org.eclipse.platform.feature.group [4.7.0,4.8.0)
[2017-11-15 12:17:53] Requirement org.eclipse.rcp.feature.group [4.7.0,4.8.0)
[2017-11-15 12:17:53] Requirement org.eclipse.buildship.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.eclemma.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.egit.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.egit.mylyn.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.jdt.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.jgit.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.m2e.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.m2e.logback.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.context_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.git.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.hudson.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.ide_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.java_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn.wikitext_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.mylyn_feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.recommenders.mylyn.rcp.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.recommenders.rcp.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.recommenders.snipmatch.rcp.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.wst.xml_ui.feature.feature.group
[2017-11-15 12:17:53] Requirement org.eclipse.oomph.setup.feature.group
[2017-11-15 12:17:53] Repository http://download.eclipse.org/technology/epp/packages/oxygen
[2017-11-15 12:17:53] Repository http://download.eclipse.org/releases/oxygen
[2017-11-15 12:17:53] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2017-11-15 12:17:59] Calculating requirements and dependencies.
[2017-11-15 12:17:59] Computing prerequisite plan
[2017-11-15 12:18:00] Fetching artifacts.xml.xz from http://download.eclipse.org/technology/epp/packages/oxygen/
[2017-11-15 12:18:01] Fetching artifacts.xml.xz from http://download.eclipse.org/releases/oxygen/201709271000/
[2017-11-15 12:18:01] Collecting 1 artifacts from http://download.eclipse.org/technology/epp/packages/oxygen
[2017-11-15 12:18:02] Downloading epp.package.java.executable.win32.win32.x86_64
[2017-11-15 12:18:02] Collected 1 artifacts for http://download.eclipse.org/technology/epp/packages/oxygen in 0.214s
[2017-11-15 12:18:02] Collecting 3 artifacts from http://download.eclipse.org/releases/oxygen
[2017-11-15 12:18:02] Downloading org.eclipse.platform.ide.executable.win32.win32.x86_64
[2017-11-15 12:18:02] Downloading org.eclipse.platform_root
[2017-11-15 12:18:02] Downloading org.eclipse.rcp_root
[2017-11-15 12:18:02] Collected 3 artifacts for http://download.eclipse.org/releases/oxygen in 0.271s
[2017-11-15 12:18:03] An error was detected while performing the engine operation and the changes are being rolled back. See the log for details.
[2017-11-15 12:18:03] ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred during the org.eclipse.equinox.internal.p2.engine.phases.CheckTrust phase.
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:280)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:547)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:340)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:729)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3324)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3252)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3233)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3133)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.installPerform(SimpleVariablePage.java:1289)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.access$32(SimpleVariablePage.java:1166)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage$20.run(SimpleVariablePage.java:1111)
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=C__Users_Peg_eclipse_java-oxygen_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.CheckTrust, operand=, action=).
ERROR: org.eclipse.equinox.p2.engine code=0 Error reading signed content.
java.io.IOException: Exception in opening zip file: C:\Users\Peg\.p2\pool\plugins\org.eclipse.aether.maven_3.1.0.v20140706-2237.jar
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:321)
at org.eclipse.osgi.internal.signedcontent.SignedBundleHook.getSignedContent(SignedBundleHook.java:212)
at org.eclipse.equinox.internal.p2.engine.phases.CertificateChecker.checkCertificates(CertificateChecker.java:74)
at org.eclipse.equinox.internal.p2.engine.phases.CertificateChecker.start(CertificateChecker.java:55)
at org.eclipse.equinox.internal.p2.engine.phases.CheckTrust.completePhase(CheckTrust.java:52)
at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:252)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:102)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:77)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:45)
at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:42)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:543)
Caused by: java.io.FileNotFoundException: C:\Users\Peg\.p2\pool\plugins\org.eclipse.aether.maven_3.1.0.v20140706-2237.jar (The system cannot find the file specified)
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:304)
... 1 more
atleast it made it farther this time
side note, when i was uninstalling, i did a search for eclipse across all of my c drive and deleted everything it would let me (might have been a bad idea in retrospect) i dont think that would completely destroy my os but idk, im interested in java not doss/c++/ whatever an os is made in
EDIT: i solved it, made the anti virus ignore .p2 aswell
[Updated on: Wed, 15 November 2017 13:34] by Moderator
Re: Installing Eclipse [message #1776380 is a reply to message #1776371] Wed, 15 November 2017 16:08 Go to previous messageGo to next message
Ok, I figured it out.
I had NetBeans installed before. It was giving problems with the Eclipse install.
I reinstalled Netbeans with Java and it solved my install problem.
[Updated on: Wed, 15 November 2017 16:09] by Moderator
Re: Installing Eclipse [message #1776400 is a reply to message #1776380] Thu, 16 November 2017 03:09 Go to previous message
Thanks for confirming it was indeed an anti-virus problem. It's really darned hard to write software that's robust when the OS (the anti-virus implementation of the OS) temporarily locks/blocks operations on files. :-(
Previous Topic:Newbie -- How to Organize my Workspace
Next Topic:How to link dynamic/shared libraries in eclipse?
Current Time: Sun Jul 20 15:39:03 EDT 2025
Powered by FUDForum. Page generated in 0.13764 seconds
