why my tests connect to AUT timeout sometimes [message #1776283] |
Tue, 14 November 2017 20:59  |
i run my tsets use autrun andt testexe but sometime an error occured and i guess it is connection timeout but i do not know how to fix this case and why timeout occur?
the log is :
17-11-15 9:07:03 - AUT is probably started with autrun yet.
17-11-15 9:07:03 - Start working with Test Job: V36FT
17-11-15 9:07:03 - Test Job "V36FT": 7 test suite executions are expected...
17-11-15 9:07:03 - Start working with Test Suite: <createSignalImportProject>
17-11-15 9:07:03 - AUT: Connecting to "V36Test"...
17-11-15 9:07:23 - AUT OK: Connection to AUT could not be established....
09:07:13.930 [Awaiting command: class org.eclipse.jubula.client.internal.commands.ConnectToAutResponseCommand] WARN o.e.j.c.i.c.ConnectToAutResponseCommand - org.eclipse.jubula.client.internal.commands.ConnectToAutResponseCommandtimeout() called
2017-11-15 09:07:23.948 [Worker-0] ERROR o.e.j.c.c.c.AUTConnection - Connection to AUT could not be established.
2017-11-15 09:07:24.161 [Worker-0] ERROR o.e.j.client.internal.BaseConnection - request() called to an unconnected connection
2017-11-15 09:07:24.164 [Worker-0] ERROR o.e.j.c.c.b.TestExecution - AUTConnection fails
org.eclipse.jubula.client.internal.BaseConnection$NotConnectedException: This connection is not connected
at org.eclipse.jubula.client.internal.BaseConnection.request(BaseConnection.java:157) ~[org.eclipse.jubula.client.api_3.3.0.201705050842.jar:na]
at org.eclipse.jubula.client.core.businessprocess.TestExecution.processCap(TestExecution.java:751) [org.eclipse.jubula.client.core_5.0.0.201705050842.jar:na]
at org.eclipse.jubula.client.core.businessprocess.TestExecution.startTestSuite(TestExecution.java:655) [org.eclipse.jubula.client.core_5.0.0.201705050842.jar:na]
at org.eclipse.jubula.client.core.businessprocess.TestExecution.executeTestSuite(TestExecution.java:372) [org.eclipse.jubula.client.core_5.0.0.201705050842.jar:na]
at org.eclipse.jubula.client.core.ClientTestImpl$1.run(ClientTestImpl.java:580) [org.eclipse.jubula.client.core_5.0.0.201705050842.jar:na]
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55) [org.eclipse.core.jobs_3.8.0.v20160509-0411.jar:na]
2017-11-15 09:07:57.976 [Connection.ReaderThread:Socket[addr=/10.93.40.164,port=60000,localport=64086]] WARN o.e.j.c.internal.Communicator - Received response org.eclipse.jubula.client.internal.commands.ConnectToAutResponseCommand@10666a1 *after* timeout expired.
2017-11-15 09:25:03.705 [Connection.ReaderThread:Socket[addr=/10.93.40.164,port=64111,localport=64098]] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error ocurred: Connection to AUT has been lost unexpectedly.
FUDForum. Page generated in 0.02915 seconds
