Home » Modeling » Papyrus » Model assistant(Model assistant deployed without any effect)
Model assistant [message #1775685] Fri, 03 November 2017 09:00 Go to next message
I generated a model *.assistant file from my *.elementtypesconfigurations file.
The elementtypesconfigurations was already deployed in a plugin.
Then I deployed the *.assistant file in a plugin using the extension point : org.eclipse.papyrus.infra.gmfdiag.assistant.modelProviders.
Unfortunately I cannot see any effect as you can see in the video : https://youtu.be/E8RGqk_2GD0
Is there an updated help or tutorial to use the assistant in Papyrus Oxygen ?
Maurice
Re: Model assistant [message #1776200 is a reply to message #1775685] Mon, 13 November 2017 11:52 Go to previous messageGo to next message
This functionality has not been modified. Have you errors logs? have you a display of assistants?
Re: Model assistant [message #1776205 is a reply to message #1776200] Mon, 13 November 2017 13:08 Go to previous message
My purpose is not to say that anything is broken.
My problem is that the help in Papyrus and the video in Youtube cannot help to setup an assistant for a DSML.
Is there any other references to setup assistants for a DSML by substituting the default objects with customized object.
Maurice
Previous Topic:no Git repositories found
Next Topic:Change displayed name on Papyrus State Diagram
Current Time: Sun Jul 20 05:57:06 EDT 2025
Powered by FUDForum. Page generated in 0.03201 seconds
