Home » Eclipse Projects » Eclipse 4 » Pragmatically resize a view
Pragmatically resize a view [message #1776032] Thu, 09 November 2017 08:48 Go to next message
Question from stackoverflow.com
I'm testing an non-e4 RCP application using SWTBot and I need to change the size of my view. (Move the sash-bar)
I unsuccessfully tried
  • Resize my view using SWTBot (no such api)
  • Resize my view using Eclipse 3 API (no supported)
  • Resize my view using underlying e4 model (resizing not working)
e4 model approach seams to be promising, but I'm missing something, so it doesn't work.
I can
  • Get MPart of my view:
    view = ePartService.findPart(ID)
  • Get MTrimmedWindow:
     window = (view as EObject).eContainer as MTrimmedWindow
I can't
  • locale correct MPartSashContainer
  • move sash-bar with setContainerData()
I would like to know:
  • How can I move from MPart to its direct parent (e.g. MPartStack)? (MPart.getParent() returns null for my view)
  • Why common EObject methods like eContainer() are not present on M... objects?
Thank you very much in advance!
[Updated on: Thu, 09 November 2017 08:56] by Moderator
Re: Pragmatically resize a view [message #1776079 is a reply to message #1776032] Fri, 10 November 2017 09:27 Go to previous messageGo to next message
Walk up your MPart's ancestry using getParent() until you reach the MPartSashContainer. It uses the values of its children's getContainerData() to serve as weights. You can adjust those values and the MPSC will resize the contents appropriately.
Re: Pragmatically resize a view [message #1776086 is a reply to message #1776079] Fri, 10 November 2017 09:47 Go to previous messageGo to next message
thank you for the response! The problem is, that the getParent() method returns NULL :(
I tried even waiting for couple of second after showing the view, but the view.getParent() continues returning NULL.
Xtend-Code:
UIThreadRunnable.syncExec(bot.getDisplay(), new Result<VoidType>() {
  override VoidType run() {
    val window = PlatformUI.getWorkbench().getActiveWorkbenchWindow();
    val page =  window.getActivePage()
    page.showView(MyView.ID, null, IWorkbenchPage.VIEW_ACTIVATE)
    null
Thread.sleep(2000)
    val eModelService = PlatformUI.getWorkbench().getService(EModelService)
    val ePartService = PlatformUI.getWorkbench().getService(EPartService)
    // Try 1
    val eView = ePartService.findPart(InterpreterView.ID)
    eView.parent // NULL
    // Try 2
    ePartService.parts.filter[ find my view  here  ].first.parent // NULL
    null
Re: Pragmatically resize a view [message #1776087 is a reply to message #1776086] Fri, 10 November 2017 09:49 Go to previous messageGo to next message
May be I'm not including some important JARs in my RCP product?
Re: Pragmatically resize a view [message #1776092 is a reply to message #1776087] Fri, 10 November 2017 10:12 Go to previous messageGo to next message
Keep ahold of the IViewPart returned by IWindow#showView() and get its MPart with something like:
IViewPart view = workbenchPage.showView(MyView.ID, ...);
part = view.getSite().getService(MPart.class);
Re: Pragmatically resize a view [message #1776097 is a reply to message #1776092] Fri, 10 November 2017 10:45 Go to previous messageGo to next message
It's still NULL :(
Debugging getParent() I get to this method
public abstract class UIElementImpl extends ... {
  @SuppressWarnings("unchecked")
  public MElementContainer<MUIElement> getParent() {
    if (eContainerFeatureID() != UiPackageImpl.UI_ELEMENT__PARENT) return null;
    return (MElementContainer<MUIElement>)eInternalContainer();
and
public class MinimalEObjectImpl extends ... {
  public int eContainerFeatureID()
    return eFlags >> 16;
The first line returns NULL:
  • UiPackageImpl.UI_ELEMENT__PARENT = 10
  • eFlags = -2359292
  • eFlags >> 16 = -36
Re: Pragmatically resize a view [message #1776257 is a reply to message #1776097] Tue, 14 November 2017 09:14 Go to previous messageGo to next message
Updated Eclipse to Neon3. The issue is still there.
Any ideas?
Re: Pragmatically resize a view [message #1776525 is a reply to message #1776257] Fri, 17 November 2017 04:42 Go to previous message
Ok, I found a solution myself.
The thing is, that the view is not a part of the e4 UI-Tree. view.eContainer is directly the MWindow. To be placed at the right spot the view is connected to the MPlaceholder, that is a part of the e4 UI-Tree and has getParent() != null.
In order to resize a view the steps are:
  • Show view
  • Find MPlaceholder of the view
  • Find MPartStack and MPartSashContainer object
  • Set containerData
  • Redraw widget (yes, auto-update seam not to work in this case)
Example:
    EModelService modelService = PlatformUI.getWorkbench().getService(EModelService.class);
    EPartService  partService  = PlatformUI.getWorkbench().getService(EPartService.class);
    // Show view
    IWorkbenchPage page = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
    page.showView(MyView.ID, null, IWorkbenchPage.VIEW_ACTIVATE);
    MPart view = partService.findPart(MyView.ID);
    // view.getParent() => null, because 'view' is not a part of the e4 UI-model!
    // It is connected to the Model using MPlaceholder
    // Let's find the placeholder
    MWindow window = (MWindow)(((EObject)eView).eContainer);
    MPlaceholder placeholder = modelService.findPlaceholderFor(window, view);
    MUIElement element = placeholder;
    MPartStack partStack = null;
	while (element != null) {
        // This may not suite your configuration of views/stacks/sashes
	    if (element instanceof MPartStack && ((Object)element.parent) instanceof MPartSashContainer) {
                partStack = (MPartStack)element;
                break;
            element = element.parent;
    if (partStack == null) { /* handle error */ }
    // Now let's change the width weights
    for (MUIElement element : partStack.getParent().getChildren()) {
        if (element == partStack) {
            element.setContainerData("50"); // Width for my view
        } else {
            element.setContainerData("25"); // Widths for other views & editors
    // Surprisingly I had to redraw tho UI manually
    // There is for sure a better way to do it. Here is my (quick & very dirty):
    partStack.toBeRendered = false
    partStack.toBeRendered = true
Please correct me, if there is a better solution.
What to give me +1? ;)) you can do it here: https://stackoverflow.com/questions/47202032/pragmatically-resize-a-view-in-eclipse/47347113#47347113
[Updated on: Fri, 17 November 2017 04:44] by Moderator
Previous Topic:Placeholders on Multi-Window
Next Topic:E4 + SWT renderer in FullScreen mode?
Current Time: Sun Jul 20 18:31:54 EDT 2025
Powered by FUDForum. Page generated in 0.05233 seconds
