NullPointerExcepiton world.esim [message #1775693] |
Fri, 03 November 2017 10:02  |
Every time I click at world.esim system node eclipse scada configuration project it pops up a window showing:
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
Checking details, I have:
at org.eclipse.emf.edit.provider.ItemProviderAdapter.getCreateChildImage(ItemProviderAdapter.java:1875)
at org.eclipse.emf.edit.command.CreateChildCommand.getImage(CreateChildCommand.java:338)
at org.eclipse.emf.edit.ui.action.StaticSelectionCommandAction.configureAction(StaticSelectionCommandAction.java:173)
at org.eclipse.emf.edit.ui.action.CreateChildAction.<init>(CreateChildAction.java:47)
at org.eclipse.emf.edit.ui.action.CreateChildAction.<init>(CreateChildAction.java:57)
at org.eclipse.scada.configuration.infrastructure.presentation.InfrastructureActionBarContributor.generateCreateChildActions(InfrastructureActionBarContributor.java:353)
at org.eclipse.scada.configuration.infrastructure.presentation.InfrastructureActionBarContributor.selectionChanged(InfrastructureActionBarContributor.java:320)
at org.eclipse.scada.configuration.infrastructure.presentation.InfrastructureEditor.setSelection(InfrastructureEditor.java:1859)
at org.eclipse.scada.configuration.infrastructure.presentation.InfrastructureEditor$6.selectionChanged(InfrastructureEditor.java:972)
at org.eclipse.jface.viewers.Viewer$1.run(Viewer.java:158)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:155)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2191)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1229)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1258)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:242)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:236)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:405)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
I´m using eclipse neon.3 4.6.3 with openscada 1.4 and neoscada 0.4.
FUDForum. Page generated in 0.29966 seconds
