Home » Modeling » Papyrus » Requirement.derived generation into document(How can I generate derived, derivedFrom, or other list typed attributes of SysML::Requirementsr::Requirement?)
Requirement.derived generation into document [message #1775026] Mon, 23 October 2017 12:57 Go to next message
I would like to ask, how can I list into a document the derived requirements of a requirement?
I try this, but it doesn't work. :-(
[for (
  d : Class |
  r.ownedElement
  ->filter(Class)
  ->select(not getAppliedStereotype('SysML::Requirements::Requirement').oclIsUndefined())
  ->sortedBy(
      c1 : Class |
      c1.getValue(
          getAppliedStereotype('SysML::Requirements::Requirement'),
          'id'
      ).toString()
Derived:
[if (d.getValue(getAppliedStereotype('SysML::Requirements::Requirement'),'derived')->flatten()->notEmpty())]<drop/>
[for (
  derived : Class |
  d.getValue(
      'derived'
  )->flatten()
)]<drop/>
[derived.getValue(getAppliedStereotype('SysML::Requirements::Requirement'),'id')/]
[/for]<drop/>
[else]<drop/>
There isn't derived requirements.
[/if]<drop/>
[/for]
The question is same the similar attributes (derivedFrom, refinedBy, etc.) of Requirement.
And somebody explain to me why I have to use 'flatten()' function?
Thank You in advance for your help.
Feri
Re: Requirement.derived generation into document [message #1775461 is a reply to message #1775026] Mon, 30 October 2017 09:14 Go to previous messageGo to next message
Nobody can help me? :-(
I have searched by Google, but I haven't found the answer. :-(
[Updated on: Mon, 30 October 2017 09:16] by Moderator
Re: Requirement.derived generation into document [message #1775466 is a reply to message #1775461] Mon, 30 October 2017 10:26 Go to previous message
You might get more response if you put OCL/Acceleo/AQL in the title line, and probably if you asked on the relevant newsgroup.
Your example appears to be Acceleo/AQL using the type-unsafe UML Java API.
But Papyrus supports the new Pivot OCL which has a typesafe stereotype API. Hovertext to help understand the type system, and a debugger when life gets hard.
I am therefore unclear what you are trying to do.
You no doubt need to flatten for the usual reason, You have a multi-depth collection.
Ed Willink
Previous Topic:Multiplicity and Navegability of an association (class)
Next Topic:Profile conversion to SysML 1.4
Current Time: Sun Jul 20 16:58:57 EDT 2025
Powered by FUDForum. Page generated in 0.03862 seconds
