Home » Newcomers » Newcomers » Having a problem trying to start eclipse
Having a problem trying to start eclipse [message #1775253] Thu, 26 October 2017 17:19 Go to next message
Ok, im a newbie at programming and i just started java classes. When i try to start eclipse (never did it before so i dont have a workspace) it simply says ''An error has ocurred, see log file", i dont understand what the log file problem means, can someone help?
Re: Having a problem trying to start eclipse [message #1775255 is a reply to message #1775253] Thu, 26 October 2017 18:01 Go to previous message
Oxygen.1a is the first release of Eclipse that is ready to run under Java 9. If you must use an older release (and you currently are using an older release), check the Wiki page at https://wiki.eclipse.org/Configure_Eclipse_for_Java_9 for instructions on adding the right startup parameters to your eclipse.ini file or shell script.
Previous Topic:Cant create New Java Project
Next Topic:a bug when close a perspective
Current Time: Sun Jul 20 07:01:06 EDT 2025
Powered by FUDForum. Page generated in 0.08036 seconds
