Home » Eclipse Projects » OM2M » raspberry as gateway
raspberry as gateway [message #1759690] Sat, 15 April 2017 16:11 Go to next message
i want to use Raspberry pi with sensor as gateway. I want to send the data from sensor on server. Should I create om2m application or new plugin?
And do I create application on gateway or server?
I could't find tutorial for this, so if you have it please send me.
Thank you
Re: raspberry as gateway [message #1760236 is a reply to message #1759690] Mon, 24 April 2017 22:08 Go to previous messageGo to next message
Hi Valentina,
You better create an application.
Thank you.
Re: raspberry as gateway [message #1760408 is a reply to message #1760236] Wed, 26 April 2017 14:07 Go to previous messageGo to next message
Thank you!
Can you also please explain me how to make connection between gateway and server. I would like to use COAP, but I'm confused what should I do on gateway and what on server.
Thank you.
Valentina
Re: raspberry as gateway [message #1775247 is a reply to message #1760408] Thu, 26 October 2017 13:45 Go to previous message
Hi Valentina,
were you able to figure how to communicate between the raspberry pi and server? Can you tell me which language did you end up using?
Umar
Previous Topic:om2m and Iot
Next Topic:MQTT Server Authorization (request/response topic)
Current Time: Sat Jul 19 05:03:21 EDT 2025
Powered by FUDForum. Page generated in 0.03092 seconds
