Registering an UML-RT Package using Extension Points [message #1775179] |
Wed, 25 October 2017 17:07  |
Hello all,
I am trying to register an UML-RT Package using the "org.eclipse.papyrus.uml.extensionpoints.UMLLibrary" extension point, so that I can import the package latter as a registered package within my UML-RT model. When I try importing the registered package, it does not import and i get the below error.
Caused by: java.io.FileNotFoundException: /packages/DetectionSensor.uml
at org.eclipse.osgi.storage.url.bundleentry.Handler.findBundleEntry(Handler.java:49)
at org.eclipse.osgi.storage.url.BundleResourceHandler.openConnection(BundleResourceHandler.java:169)
at java.net.URL.openConnection(Unknown Source)
at org.eclipse.core.internal.boot.PlatformURLConnection.connect(PlatformURLConnection.java:112)
at org.eclipse.core.internal.boot.PlatformURLConnection.connect(PlatformURLConnection.java:93)
at org.eclipse.core.internal.boot.PlatformURLConnection.getInputStream(PlatformURLConnection.java:228)
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:207)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
Eclipse is unable to find the UML file, even though i included it in the binary build.
The path i had given while registering using the extension point is : platform:/plugin/ca.queensu.cs.rover.configuration/packages/DetectionSensor.uml
Any help or pointers will be really helpful !
Thank you.
Sudharshan
Re: Registering an UML-RT Package using Extension Points [message #1775245 is a reply to message #1775179] |
Thu, 26 October 2017 13:07  |
I'm not sure what's the problem. You can try this: make sure you include the "packages" folder in your build.properties file and also the "plugin.xml" file.
For example
bin.includes = META-INF/,\
plugin.xml,\
about.html,\
packages/
Also, I would recommend that instead of using platform:/plugins/... directly, you create an ecore pathmap mapping like this:
<extension point="org.eclipse.emf.ecore.uri_mapping">
<mapping
source="pathmap://ROVER_LIB/"
target="platform:/plugin/ca.queensu.cs.rover.configuration/packages/"/>
</extension>
and then in the extension point for the library:
<extension point="org.eclipse.papyrus.uml.extensionpoints.UMLLibrary">
<library
description="Rover Library"
name="Rover Library"
path="pathmap://ROVER_LIB/DetectionSensor.uml"/>
</extension>
Although I'm not sure this is necessary, also make your plugin a singleton and activate when a class from the plug-in is loaded (Overview tab of the MANIFEST.MF).
FUDForum. Page generated in 0.02790 seconds
