Home » Eclipse Projects » Eclipse Scout » Eclipse Scout(Is scout a viable choice for production development?)
Eclipse Scout [message #1774807] Thu, 19 October 2017 14:55 Go to next message
Is Scout a viable choice for production development? I have just discovered its existence. I do not see a lot of documentation on it.
Re: Eclipse Scout [message #1774822 is a reply to message #1774807] Fri, 20 October 2017 02:35 Go to previous messageGo to next message
You might ask on their specific forum https://www.eclipse.org/forums/index.php?t=thread&frm_id=174 but I imagine the answer is most definitely yes.
Re: Eclipse Scout [message #1774964 is a reply to message #1774822] Sun, 22 October 2017 16:57 Go to previous messageGo to next message
We've been running three large scout applications in productive use for 3 years now, first as rich clients using Scout Mars and since June 2017 as web clients using Scout Neon.
Re: Eclipse Scout [message #1774985 is a reply to message #1774964] Mon, 23 October 2017 04:16 Go to previous messageGo to next message
We are running a small application for a year now, every day 30 concurrent users. This is not much, but in all the time, Scout was stable, fast and consumes a very small amount of system resources.
[Updated on: Mon, 23 October 2017 04:18] by Moderator
Re: Eclipse Scout [message #1775007 is a reply to message #1774985] Mon, 23 October 2017 08:46 Go to previous messageGo to next message
Thanks for the feedback guys.
Any suggestions on documentation? And Is Tomcat the preferred web server?
I am interested in possibly using it for business data collection and integrating BIRT for reporting.
Thanks again.
Dan
[Updated on: Mon, 23 October 2017 08:49] by Moderator
Re: Eclipse Scout [message #1775008 is a reply to message #1774985] Mon, 23 October 2017 08:46 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 23 October 2017 08:48] by Moderator
Re: Eclipse Scout [message #1775009 is a reply to message #1774985] Mon, 23 October 2017 08:46 Go to previous messageGo to next message
No Message Body
Re: Eclipse Scout [message #1775010 is a reply to message #1774985] Mon, 23 October 2017 08:47 Go to previous messageGo to next message
No Message Body
Re: Eclipse Scout [message #1775011 is a reply to message #1775010] Mon, 23 October 2017 08:57 Go to previous messageGo to next message
First go through the beginner's guide, then read the Technical Doc. These two documents are enough to get you started.
Re: Eclipse Scout [message #1775012 is a reply to message #1775011] Mon, 23 October 2017 09:01 Go to previous messageGo to next message
Roger that. Thanks for the quick reply Benjamin.
Re: Eclipse Scout [message #1775334 is a reply to message #1774807] Fri, 27 October 2017 15:48 Go to previous messageGo to next message
No Message Body
[Updated on: Fri, 27 October 2017 15:52] by Moderator
Re: Eclipse Scout [message #1775335 is a reply to message #1774807] Fri, 27 October 2017 15:50 Go to previous message
Hi Dan,
we use Scout since 2015. We are mainly on consulting projects but have developed a core application in Scout and finished two use case driven solutions for our customers (banks). In both use cases we manage data, run calculations on the DB (and in the background via python) and generate reports.
In my experience, Scout runs very stable and the framework is mature, we made use of the scout tutorials (which were now replaced by the two documents mentioned by Benjamin) to get used to the framework. In the Scout-Widget application and the Contacts Demo is a lot of open source code. In summary we were able to solve the customers use cases with a small team and QA.
If you need help (we developed a LDAP connector and other stuff ourselves), feel free to ask.
Best,
David
Previous Topic:Eclipse Scout disable login?
Next Topic:No application id has been found
Current Time: Sun Jul 20 09:14:45 EDT 2025
Powered by FUDForum. Page generated in 0.05186 seconds
