After updating Eclipse NEON to Oxygen, errors [message #1774629] |
Wed, 18 October 2017 03:00  |
I had Eclipse NEON 3 install on my laptop, once i tried to upgrade it to Eclipse Oxygen (4.7.1) i got error message in my log as following:
SESSION 2017-10-18 08:49:52.772 -----------------------------------------------
eclipse.buildId=4.7.1.M20171009-0410
java.version=1.8.0_111
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.php.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.php.product
!ENTRY org.eclipse.osgi 4 0 2017-10-18 08:49:57.266
!MESSAGE Application error
!STACK 1
java.lang.LinkageError: loader constraint violation: loader (instance of org/eclipse/osgi/internal/loader/EquinoxClassLoader) previously initiated loading for a different type with name "org/eclipse/core/commands/IHandler"
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:276)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:655)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:578)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.core.commands.Command.setHandler(Command.java:974)
at org.eclipse.ui.internal.commands.CommandPersistence.readCommandsFromRegistry(CommandPersistence.java:210)
at org.eclipse.ui.internal.commands.CommandPersistence.reRead(CommandPersistence.java:502)
at org.eclipse.ui.internal.CommandToModelProcessor.process(CommandToModelProcessor.java:68)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:305)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:233)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:107)
at org.eclipse.e4.ui.internal.workbench.ModelAssembler.runProcessor(ModelAssembler.java:362)
at org.eclipse.e4.ui.internal.workbench.ModelAssembler.runProcessors(ModelAssembler.java:324)
at org.eclipse.e4.ui.internal.workbench.ModelAssembler.processModel(ModelAssembler.java:97)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:197)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:378)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:253)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:614)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
basically i understand that :java.lang.LinkageError: loader constraint violation: loader (instance of org/eclipse/osgi/internal/loader/EquinoxClassLoader) previously initiated loading for a different type with name "org/eclipse/core/commands/IHandler"
is the error. SO what should i do ? Because updating process happened correctly.
thx
FUDForum. Page generated in 0.28765 seconds
