Home » Eclipse Projects » Eclipse 4 » How to close the workbench from an other bundle
How to close the workbench from an other bundle [message #1774165] Wed, 11 October 2017 04:43 Go to next message
Hi, I have an eclipse e4 app and a bundle that has no dependencies to the app bundle. From this other bundle I want to quit the app if some condition is not fullfilled. How can I obtain programmatically a workbench to close the application? This bundle has no parts (Just headless code and some wizards (JFace). Thank you!
Re: How to close the workbench from an other bundle [message #1774402 is a reply to message #1774165] Fri, 13 October 2017 13:05 Go to previous messageGo to next message
You can use `Display#close()`, though this calls out to all `SWT.Close` listeners which can refuse the attempt.
You could also use `Display#dispose()`, though that's fairly brutish.
Alternatively, the E4Application is an Equinox IApplication, and these are available from the service registry, and you can issue a #stop() to the IApplication instance.
Re: How to close the workbench from an other bundle (SOLVED) [message #1774536 is a reply to message #1774402] Mon, 16 October 2017 17:16 Go to previous message
HI Brian
many thanks for your hints. Because I did not find any service with interface IApplication I tried to close the IWorkbench that is available from service registry. But I had then to use Display.close() because the workbench (thought available) did not as I expected. Display.close() seems to me the best of the variants.
Previous Topic:SceneBuilder integration
Next Topic:How to change the background color of the main menu by CSS in eclipse?
Current Time: Sun Jul 20 08:42:31 EDT 2025
Powered by FUDForum. Page generated in 0.04058 seconds
