[Edapt] Can't migrate model after referenced model is migrated? [message #1757503] |
Sun, 19 March 2017 14:58  |
I have multiple models generated from the same ecore metamodel and the models reference each other
Example:
mymodel.ecore ---> mymodel1, mymodel2
mymodel2 references mymodel1
When using Edapt to migrate the models. If I migrate mymodel1 before attempting to migrate mymodel2 then mymodel2 migration fails with the following errors (only the first line of the trace provided for readability):
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri '{model uri}/1.9' not found. (platform:/resource/aa/{model 2}, 2, 241)
org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'Package' is not found or is abstract. (platform:/resource/aa/{model 2}, 2, 241)
I've found that if I migrate mymodel2 first then it will work and mymodel1 will also be migrated correctly as a side effect.
The problem is that since I have multiple models that reference mymodel1 after migrating mymodel2 all subsequent migrations fail. I can work around this issue by replacing mymodel1 with an older version before I migrate each model that references it but this becomes really annoying and not a good experience to the customers who have their own models that reference the mymodel1 we provide.
Is there a recommended method for handling this situation?
I did a forum search but couldn't find anything that seemed to answer my question. I'm fairly new to Edapt and EMF so any help would be appreciated.
FUDForum. Page generated in 0.06645 seconds
