Home » Archived » BIRT » Parameter wildcard value(using wildcard in poarameter default value)
Parameter wildcard value [message #1773016] Wed, 20 September 2017 04:28 Go to next message
Hi experts,
a very urgent question regarding setting parameter default value as wildcard,
I am using sql queries, I have a set of parameters strings and ints, I have applied * and % but it doesn't seem to work,
dataset query:
select x,c,v,b,n
where c= ?
and v=?
b =?
dataset parameter:
param 1 linked c
param2 linked v
param3 linked b
report parameter:
c
type= string
Default value ( here I want to apply a wild card where user can either run and get all Cs or change and write a string where they run the report )
here is more info
BIRT Report Designer 2.6.1 Report Version 3.2.22 ( RCP)
any help appreciate it,
thanks
Re: Parameter wildcard value [message #1773048 is a reply to message #1773016] Wed, 20 September 2017 15:39 Go to previous messageGo to next message
The way that I handle this is to remove the ? marks and data set parameters and use a 'beforeOpen' script instead. I use something like the following that basically allows you to do almost any thing you can do in SQL
// Append Where Clause for Agency
if (params["rprmAgency"].value != "ALL"){
this.queryText = this.queryText + " and ROOT.AE_B_LSE_E.COMPANY_ID = '" + params["rprmAgency"]+"'"
// Append Where Clause for Option Status
if (params["rprmStatus"].value != "ALL"){
this.queryText = this.queryText + " and (ROOT.AE_B_OPN_D.ACTIVE is Null or ROOT.AE_B_OPN_D.ACTIVE = 'Y')"
// Append Order By Clause
this.queryText = this.queryText + "order by ROOT.AE_B_OPN_D.LEASE_NO,ROOT.AE_B_OPN_D.SEQ_NUM"
Re: Parameter wildcard value [message #1773049 is a reply to message #1773016] Wed, 20 September 2017 15:39 Go to previous messageGo to next message
Re: Parameter wildcard value [message #1773478 is a reply to message #1773049] Thu, 28 September 2017 09:39 Go to previous message
thanks it is working now :)
Previous Topic:Birt 4.6 intergration with Wildfly 10.1.0
Next Topic:Filed colour
Current Time: Sat Jul 19 22:56:41 EDT 2025
Powered by FUDForum. Page generated in 0.04202 seconds
