Home » Language IDEs » Java Development Tools (JDT) » Is it possible to Edit Java Builder ??(I want to edit the java builder functionality )
Is it possible to Edit Java Builder ?? [message #1769783] Thu, 03 August 2017 07:24 Go to next message
I want when Developer save java file in eclipse , And eclipse by default generate it .class file in bin folder,So this only (Updated class file) .class file will also generate in other folder (Not all the class file of project only the changed .class file ). I can not copy /paste that bin class file to new desired location because of client restriction. So only option remaining of doing this is to somehow give two path one is of bin folder path & other is of my new folder path so when Developer press Ctrl+S ,eclipse automatically generate .class in two different locations.
I think java builder do the same, but only generate/update .class in bin folder also with other class file of project,
I want only the generate/updated .class file in new folder, not all the class files of project. How should i do this ??
see the attachment for more details
  • Attachment: issue.png
    (Size: 9.63KB, Downloaded 110 times)
    (Size: 9.63KB, Downloaded 115 times)
Re: Is it possible to Edit Java Builder ?? [message #1773193 is a reply to message #1769783] Sat, 23 September 2017 02:07 Go to previous message
You want to modify an immutable object. Do you see the problem there? Either add setters (or any methods that mutate the state) or accept that the object is immutable.
You can of course create a new object based on the values of the old one, but it won't be the same object then.
Previous Topic:Eclipse - Debugging Issue about F5
Next Topic:Eclipse download is very slow
Current Time: Sat Jul 19 19:19:53 EDT 2025
Powered by FUDForum. Page generated in 0.03628 seconds
