Home » Modeling » TMF (Xtext) » Problem with multiple ecore refering
Problem with multiple ecore refering [message #1772902] Mon, 18 September 2017 10:15 Go to next message
Hello everyone,
I'm creating an Xtext grammar to a metamodel I have for some time.
There is an important information regarding this metamodel: It extends another metamodel (lets call it metamodel A).
I would like to build an xtext grammar for the extended metamodel, but only defining the necessary types for the metamodel A. The file extensions are different, depending on which model the user chooses to create the file.
I defined the whole grammar for my metamodel, including the required rules for metamodel A, so the grammar would make sense.
However, now I'm trying to build the project and I'm getting an error
[ERROR]: GeneratorException: (Element: -UNKNOWN-; Reported by: XtextGenerator)
java.lang.IllegalArgumentException: Cannot determine the package name of '<Model>.<ModelPackage>'. Please use the TypeReference(packageName, className) constructor
at org.eclipse.xtext.xtext.generator.model.TypeReference.getPackageName(TypeReference.java:164)
I added the referencedResource to the workflow file as instructed by a tutorial I found, but the problem persists. I'm using xtext version 2.12.0.
Thanks in advance.
Workflow file (simplified, it is mostly the same generated by xtext)
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
component = XtextGenerator {
language = StandardLanguage {
referencedResource = "<MyModel>.genmodel"
referencedResource = "<ModelA>.genmodel"
fragment = ecore2xtext.Ecore2XtextValueConverterServiceFragment2 auto-inject {}
fragment = org.eclipse.xtext.generator.adapter.FragmentAdapter {
fragment = org.eclipse.xtext.generator.ecore2xtext.FormatterFragment {}
serializer = {
generateStub = false
Re: Problem with multiple ecore refering [message #1772903 is a reply to message #1772902] Mon, 18 September 2017 10:26 Go to previous messageGo to next message
are you sure your ecore sticks to java naming conversions egarding package and class names?
Re: Problem with multiple ecore refering [message #1772904 is a reply to message #1772903] Mon, 18 September 2017 10:29 Go to previous message
see https://github.com/eclipse/xtext-core/issues/161
Previous Topic:Partial Parsing Problem
Next Topic:Xtext parser rules overlap problem
Current Time: Sat Jul 19 13:24:59 EDT 2025
Powered by FUDForum. Page generated in 0.05494 seconds
