Home » Newcomers » Newcomers » How to fix bugs in Eclipse
How to fix bugs in Eclipse [message #1772638] Wed, 13 September 2017 08:51 Go to next message
I am running on Eclipse Oxygen and I want to debug a problem I am encountering in the Mylyn Github connector. The only articles I can find on how to debug a problem in Eclipse date from 2008 and deal with the CVS environment, not with GIT or GERRIT. Is there a modern article that covers how to identify the source that contains the problem, how to get the appropriate source and how to setup and use a debugging environment to investigate the problem?
[Updated on: Wed, 13 September 2017 08:53] by Moderator
Re: How to fix bugs in Eclipse [message #1772646 is a reply to message #1772638] Wed, 13 September 2017 10:20 Go to previous message
There is this page:
https://wiki.eclipse.org/Mylyn/Contributor_Reference
It includes instructions for how to use Oomph to do the setup for you:
https://wiki.eclipse.org/Mylyn/Contributor_Reference#Setup_Using_Oomph
You could get a Gerrit access for your Eclipse account and will then be able to commit contributions to Gerrit for review:
https://wiki.eclipse.org/Gerrit#User_Account
Previous Topic:Eclipse Oxygen is broken: Splash shows on startup, then Eclipse closes
Next Topic:Bypass errors in either of the codes
Current Time: Sun Jul 20 13:07:30 EDT 2025
Powered by FUDForum. Page generated in 0.28753 seconds
