Home » Modeling » TMF (Xtext) » How to specify an array value in mwe2
How to specify an array value in mwe2 [message #1772598] Tue, 12 September 2017 18:19 Go to next message
So if my fragment class has a String array data member, or an ArrayList<String> data member, how do I initialize it in mwe2?
for example:
mwe2...
fragment = MyFragment {
	myList = ArrayList {
fragment...
class MyFragment extends AbstractXtextGeneratorFragment {
	@Accessors ArrayList<String> myList
I can't seem to find the syntax for filling the ArrayList. Or the only way is to create addMyListItem(String i) method?
Re: How to specify an array value in mwe2 [message #1772609 is a reply to message #1772598] Wed, 13 September 2017 00:46 Go to previous messageGo to next message
You usually add a method addXxxx
And the do xxxx = "a" xxxx="b" in the workflow
you might have a look at this hidden treasure that was removed for whyever from the main xtext doc (maybe cause it parially outdated, i dont know)
https://eclipse.org/Xtext/documentation/306_mwe2.html
[Updated on: Wed, 13 September 2017 01:05] by Moderator
Re: How to specify an array value in mwe2 [message #1772611 is a reply to message #1772609] Wed, 13 September 2017 00:57 Go to previous message
example:
validator = {
composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
composedCheck = "bla.blubb.Validator"
val List<String> composedChecks = newArrayList
* Adds a validator that is to be executed additionally.
* @param composedCheckValidator
* name of a class extending {@link AbstractDeclarativeValidator}
def void addComposedCheck(String composedCheckValidator) {
composedChecks += composedCheckValidator
Previous Topic:How to get images from other plug-in using PluginImageHelper
Next Topic:tycho question. postpone xtend source code generation
Current Time: Sun Jul 20 04:22:12 EDT 2025
Powered by FUDForum. Page generated in 0.03589 seconds
