Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #176685] |
Mon, 11 April 2005 14:40  |
Originally posted by: kevinlouisnospam.hotmail.com
WorkbenchMessages and GEFMessages have some common message, e.g.
"Workbench.copyToolTip" and "GEFMessages.CopyAction_Tooltip".
I want to see if there is any special reason why GEF does not use the
Workbench on and create its own set. I am going to use the
WorkbenchMessages only as GEF does not have cut action.
Kevin.
Re: Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #177187 is a reply to message #177096] |
Tue, 12 April 2005 18:28   |
Hi Randy,
In that case, why don't you provide a complete set of actions strings then?
For example, I need to implement the Cut Action, but GEFMessages only has
copy and paste. I need to use the WorkbenchMessages one.
Actually, why is the WorkbenchMessages from someone else? Is it from
Eclipse too?
Kevin
"Randy Hudson" <none@us.ibm.com> wrote in message
news:d3h7rs$d6v$1@news.eclipse.org...
> That's our internal package vs. someone else's over which we have no
> control.
> "Kevin" <kevinlouisnospam@hotmail.com> wrote in message
> news:d3f60d$ihi$1@news.eclipse.org...
> > GEFMessages is in the org.eclipse.gef.internal too. I don't see it is a
> > good reason why GEFMessage is used, instead of the
> > org.eclipse.ui.internal.WorkbenchMessages.
> > "Pratik Shah" <ppshah@us.ibm.com> wrote in message
> > news:d3eqr2$6a2$1@news.eclipse.org...
> >> Because WorkbenchMessages is internal.
> >> news:d3eglt$mm3$1@news.eclipse.org...
> >> > Hi,
> >> > Thanks,
> >> > Kevin.
FUDForum. Page generated in 0.45252 seconds
