Home » Eclipse Projects » Buildship » Cannot generate a BW Object in Eclipse Neon 3(Problems when generating an object)
Cannot generate a BW Object in Eclipse Neon 3 [message #1771950] Fri, 01 September 2017 08:43
Hi guys,
I am a newcomer to that topic, hence please excuse certain lack of knowledge...
In my current Eclipse Neon 3 - BW Modelling session, I am trying to generate a BW Info Area. I am getting the following error log:
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:398)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:993)
at com.sap.bw.editor.ui.wizard.BwWizardDialog.performFinish(BwWizardDialog.java:548)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:790)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:423)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at com.sap.bw.editor.ui.wizard.BwWizardDialog.start(BwWizardDialog.java:1076)
at com.sap.bw.core.ui.ext.AbstractWizardService.startWizard(AbstractWizardService.java:233)
at com.sap.bw.projectexplorer.ui.actions.StartWizardAction.run(StartWizardAction.java:217)
at org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEvent(BaseSelectionListenerAction.java:167)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at com.sap.adt.transport.internal.TransportServiceImpl.getUrifromDiscoveryInCtsScheme(TransportServiceImpl.java:97)
at com.sap.adt.transport.internal.TransportServiceImpl.getTransportChecksURI(TransportServiceImpl.java:265)
at com.sap.adt.transport.internal.TransportServiceImpl.check(TransportServiceImpl.java:219)
at com.sap.adt.transport.internal.TransportServiceImpl.check(TransportServiceImpl.java:186)
at com.sap.bw.connectivity.services.internal.BwTransportService.ensureLockedOnTransport(BwTransportService.java:303)
at com.sap.bw.connectivity.services.internal.WizardService.post(WizardService.java:140)
at com.sap.bw.editor.ui.wizard.BwWizardDialog.doPerformFinish(BwWizardDialog.java:672)
at com.sap.bw.editor.ui.wizard.BwWizardDialog$1.run(BwWizardDialog.java:551)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Session Data:
eclipse.buildId=4.6.3.M20170301-0400
java.version=1.8.0_141
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -data file:/C:/Users/cdreesba/workspace/ -product org.eclipse.epp.package.jee.product
Would anyone have a clue what the root cause of this problem might be?
Many thanks for your ideas!
Cheers
Claus
Previous Topic:Gradle Can't Find Obviously There Projects
Next Topic:Example Project fails at test run
Current Time: Sat Jul 19 13:01:52 EDT 2025
Powered by FUDForum. Page generated in 0.04753 seconds
