Home » Modeling » Papyrus » C++ Reverse Engineering
C++ Reverse Engineering [message #1769992] Mon, 07 August 2017 06:55 Go to next message
Hi.
I recently tested the C++ reverse engineering functionality of papyrus / papyrus designer and noticed a strange thing.
Setup:
Ubuntu 14.04
- Clean Eclipse Oxygen CDT platform
- Papyrus 3 ; Update-Site: http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/oxygen
- Papyrus C++ Profile; Update-Site: http://download.eclipse.org/modeling/mdt/papyrus/components/designer/
Also tested it with Neon platform and papyrus 2 resulting in the same issue...
Problem:
After setting up a C++ project and creating one "TestClass" with primitive member-variables i created a papyrus model over the menu-entry "Reverse->To new UML model".
The "Model Explorer" and "Property" view show up the members as expected. The latter as "Owned attribute". If i put the Class-Model in a diagram i could select the attributes to show up ("Right-click TestClass->Filters->Show/Hide Contents). But the attributes created in the code are not in the list of "Select element to show". Only attributes i additionally added with the editor are available. If i copy an reverse-engineered attribute and paste it it is also selectable.
Reverse-engineered operations do the trick and are visible.
Just wanted to mention. Maybe there is an option to activate?
Tobi
Re: C++ Reverse Engineering [message #1771172 is a reply to message #1769992] Tue, 22 August 2017 11:42 Go to previous messageGo to next message
Do you use a nightly Papyrus? (update site: http://download.eclipse.org/modeling/mdt/papyrus/updates/nightly/oxygen)
Properties created by reverse engineering belong to an association. The bug 512760 caused that these properties don't show up in the attribute list. As the bug has been fixed, it should now be possible to show attributes from reverse-engineering, both for oxygen and neon. Can you please re-try with a nightly build? (of course, unless you are already using one - which seems unlikely, as I can't reproduce the issue on my machine).
Re: C++ Reverse Engineering [message #1771525 is a reply to message #1771172] Sat, 26 August 2017 12:46 Go to previous messageGo to next message
I was not using the oxygen-nightlies. With the nightly-build it works like a charm.
Thank you :)
Re: C++ Reverse Engineering [message #1771703 is a reply to message #1771525] Tue, 29 August 2017 12:28 Go to previous messageGo to next message
I currently facing the problem with the current nightlies: The reverse-engineering works but i am not able to create a new model with a class-diagram. Eclipse reported the following:
REPORT
anonymousId 1e158d66-173f-4bb2-a820-a1f94c391e1c
name
email
comment
eclipseBuildId 4.7.0.I20170612-0950
eclipseProduct org.eclipse.epp.package.cpp.product
javaRuntimeVersion 1.8.0_131-b11
osgiWs gtk
osgiOs Linux
osgiOsVersion 4.4.0
osgiArch x86_64
severity UNKNOWN
STATUS
pluginId org.eclipse.ui
pluginVersion 3.109.0.v20170411-1742
code 0
severity 4
message Unhandled event loop exception
fingerprint a3ccc82ee5ca4a209ed789ff7d23d3c1
Exception:java.lang.NullPointerException: null
at org.eclipse.papyrus.infra.internationalization.modelresource.InternationalizationModelResource.createModel(InternationalizationModelResource.java:466)
at org.eclipse.papyrus.infra.core.resource.ModelSet.createModels(ModelSet.java:471)
at org.eclipse.papyrus.uml.diagram.wizards.command.NewPapyrusModelCommand.doExecute(NewPapyrusModelCommand.java:52)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:488)
at org.eclipse.papyrus.infra.emf.gmf.command.CheckedOperationHistory.doExecute(CheckedOperationHistory.java:206)
at org.eclipse.papyrus.infra.emf.gmf.command.CheckedOperationHistory.execute(CheckedOperationHistory.java:195)
at org.eclipse.papyrus.infra.emf.gmf.command.NotifyingWorkspaceCommandStack.doExecute(NotifyingWorkspaceCommandStack.java:264)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.papyrus.infra.emf.gmf.command.NestingNotifyingWorkspaceCommandStack.execute(NestingNotifyingWorkspaceCommandStack.java:130)
at org.eclipse.papyrus.uml.diagram.wizards.wizards.CreateModelWizard.createPapyrusModels(CreateModelWizard.java:645)
at org.eclipse.papyrus.uml.diagram.wizards.wizards.InitModelWizard.createPapyrusModels(InitModelWizard.java:165)
at org.eclipse.papyrus.uml.diagram.wizards.wizards.CreateModelWizard.createAndOpenPapyrusModel(CreateModelWizard.java:320)
at org.eclipse.papyrus.uml.diagram.wizards.wizards.CreateModelWizard.performFinish(CreateModelWizard.java:280)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:778)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:417)
at org.eclipse.jface.dialogs.Dialog.lambda$0(Dialog.java:619)
at org.eclipse.swt.events.SelectionListener$1.widgetSelected(SelectionListener.java:81)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5252)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1348)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4522)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4107)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:269)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:290)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:291)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:92)
at sun.reflect.NativeMethodAccessorImpl.invoke0(NativeMethodAccessorImpl.java:-2)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:305)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:239)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:390)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:151)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1044)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
BUNDLES
name org.eclipse.core.commands
version 3.9.0.v20170530-1048
name org.eclipse.core.databinding.observable
version 1.6.100.v20170515-1119
name org.eclipse.core.runtime
version 3.13.0.v20170207-1030
name org.eclipse.e4.core.commands
version 0.12.100.v20170513-0428
name org.eclipse.e4.core.contexts
version 1.6.0.v20170322-1144
name org.eclipse.e4.core.di
version 1.6.100.v20170421-1418
name org.eclipse.e4.ui.workbench
version 1.5.0.v20170412-0908
name org.eclipse.e4.ui.workbench.swt
version 0.14.100.v20170519-1601
name org.eclipse.emf.transaction
version 1.9.0.201706061339
version 2.6.0.v20170609-0928
name org.eclipse.emf.workspace
version 1.5.1.201706061339
name org.eclipse.equinox.app
version 1.3.400.v20150715-1528
name org.eclipse.equinox.launcher
version 1.4.0.v20161219-1356
name org.eclipse.jface
version 3.13.0.v20170503-1507
name org.eclipse.papyrus.infra.core
version 3.0.0.201708231432
name org.eclipse.papyrus.infra.emf.gmf
version 1.2.100.201708231432
name org.eclipse.papyrus.infra.internationalization
version 1.0.0.201708231432
name org.eclipse.papyrus.uml.diagram.wizards
version 3.0.1.201708231432
name org.eclipse.swt
version 3.106.0.v20170608-0516
name org.eclipse.ui
version 3.109.0.v20170411-1742
name org.eclipse.ui.ide.application
version 1.2.0.v20170512-1452
version 3.13.0.v20170516-1223
Work-Around: Papyrus-Preferences-> Internationalization -> uncheck "Load internationalization files ..."
[Updated on: Sat, 02 September 2017 20:17] by Moderator
Re: C++ Reverse Engineering [message #1772200 is a reply to message #1771703] Wed, 06 September 2017 10:29 Go to previous message
thanks for pointing this out. I'll check why internationalisation is not initialized at this point.
Previous Topic:Generating UML Diagram class
Next Topic:Proper steps to import OMG's ISO 80000 package into SysML?
Current Time: Sat Jul 19 17:18:12 EDT 2025
Powered by FUDForum. Page generated in 0.03871 seconds
